Seat question
Seat question
Do the leather seats on the new super duties come with cooled leather seats. In 08 I know they came out with heated but you don't need that if you live in AZ.
If they do would the conversion be the same as what BuiltFordTough! did with the 08 heated seats or do cooled seat work differently?
yes, the newer seats come with heated and cooled
You can do it the easy way or hard way. Easy way is to simply wire them in and let the seat pull "cooler" air from the cab surroundings.
Hard way is to run a/c ducting under the carpet to the intake port of the fan. This lets "cold" air be blown on your behind.
Loved the seats in my Expy when they worked. Kinda loud though. Like a fan right in your ear when in fast speed though. Could only stand them in slow speed because of the fan noise.
if you've never experienced the a/c seats before...beware a hot day while being active.
lets just say it's a little disconcerting to hop in there all sweaty and have all that cold air going to your nether regions. kinda like putting your favorite frosty beverage between your legs while driving.
Also, which is is better to do if you want to reduce the noise...
"You can do it the easy way or hard way. Easy way is to simply wire them in and let the seat pull "cooler" air from the cab surroundings.
Hard way is to run a/c ducting under the carpet to the intake port of the fan. This lets "cold" air be blown on your behind."
the seats are noisy any way you put them. slow speed fans fade into the ambient noise while driving. fast and medium speed are noticeable.
as for doing it the "hard" or "easy" way, that is really only for your temperature preference. easy won't be as cool..same temp as ambient temp inside the cabin. hard will be whatever the temp of the air blowing out the vents on the dash
