Diesel in radiator - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Diesel in radiator
Old 07-24-2012, 07:27 PM
AKFORD4x4 AKFORD4x4 is offline
AKFORD4x4 is starting off with a positive reputation.
Diesel in radiator
So the previous owner had bad injector cups and they were all replaced as well as injectors before I bought the truck. He did not however flush out the radiator before he sold it to me and he DID tell me that he didn't get a chance to flush it yet. The trucks running great, good heater, normal operating temps but the coolant is very dark colored and smells like Diesel fuel. I WILL get to flushing it out in the next few weeks but my question is this: IS it doing anykind of damage to my cooling system or the truck by driving it like this?.
Old 07-24-2012, 08:02 PM
roaddogjru roaddogjru is offline
roaddogjru is starting off with a positive reputation.
It will not hurt it to drive with a little diesel in the radiator. I know a person that drove thousands of miles with leaking cups and sucked the fuel off the coolant in the puke tank every night.
Run straight water for a month, flush it and put coolant in. You will still have some residual, less that 1/4 inch usually so you may have to suck it off several times before it stops. Put some Water Wetter in.
Old 07-24-2012, 08:53 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Think of it as water pump lubricant.
Old 07-24-2012, 10:07 PM
Jmatthews's Avatar
Jmatthews Jmatthews is offline
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
I ran water through mine for a while and put in a little purple power every now and then and drained the radiator almost every evening after work. It cleaned it out well. then I did a flush and fill on last time like you are supposed to.
Old 07-26-2012, 08:40 AM
RPM371's Avatar
RPM371 RPM371 is offline
RPM371 is gaining momentum as a positive member of FTE.RPM371 is gaining momentum as a positive member of FTE.
Diesel will degrade the coolant hoses and degas bottle.
Old 07-26-2012, 11:35 AM
The esters in diesel will degrade natural rubber. Modern hoses and seals are all Buna N, Nitrile, Silicone or a combination of these and sometimes contain teflon also. The only oils that will attack these compounds are jet oils per MIL-PRF-26399 or PRI-QPL-AS5780. These oils will eat the soles off your shoes but are not used in diesel applications.
The puke tank composition will not be effected by engine oil but it will discolor it which makes it look like it is going bad.
7.3 coolant additive ace 1999 to 2016 Super Duty 4 03-06-2015 07:36 PM
Coolant Flush After Injector Cup Replacement kush1972 1999 - 2003 7.3L Power Stroke Diesel 4 01-25-2014 07:27 AM
Injector Cup Heartbreak AK Rice 1999 - 2003 7.3L Power Stroke Diesel 12 03-09-2013 10:06 PM
Funky smelling coolant SCA - diesel? olfordsnstone 6.0L Power Stroke Diesel 8 02-28-2013 09:33 PM
Radiator Woes - 2001 SVT Lightning silversvt01 New Member Introductions 2 04-17-2007 06:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
