Diesel smell when A/C is on?
Have a diesel smell in the cab when a/c is on, but I turn on the a/c reculation button it goes away. Climbed all over and under truck and no visible leaks.
Cool but confused.
Items replaced :
Heads and studs a year ago
EGR delete same time
Oil cooler. Two weeks ago
Cool but confused.
Items replaced :
Good point. I had a similar situation... I couldn't see a leak but could smell diesel fuel. Once the leak got worse from the pressure spring housing, I could finally see the fuel dripping. Look really good around the housing with the engine running.
99ExpyProblems
09-15-2013 10:34 PM
hasteranger
10-11-2011 08:23 PM
