f-250 brake shoe
Old 07-26-2012, 03:21 PM
99hosss's Avatar
99hosss
99hosss is offline
f-250 brake shoe
Hello Forum, I'm not trusting the auto parts guys on this question- when I buy a set of front/back shoes for the 60- f-250, is it a standard set, or are the backs larger? I know one side is larger, but is that the case all the way around? thanks
Old 07-26-2012, 05:32 PM
F250racer's Avatar
F250racer
F250racer is offline
Not 100% sure but I believe that for that truck all four are the same shoe, meaning the set for the rear axle and the set for the front axle should be the same NAPA part number. The only difference should be at each drum, meaning for the right front drum one shoe will be slightly different than the other. I think one will have a little less pad or be tapered off a little differently.
Old 07-26-2012, 06:21 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Not sure if I follow just what your question is. Each drum should have a primary and secondary shoe primary(short lining) to the front, secondary to the rear.
Good luck in your quest
webstar61
01-13-2013 12:07 PM
Bootlegger's Deluxe
13
12-28-2011 12:06 AM
1994F2507.3L
17
05-18-2010 01:28 AM
10strokin
07-14-2008 01:57 PM
GRG
03-08-2004 08:16 PM
Quick Reply: f-250 brake shoe
