2001 F250 v10, This problem has got me stumpped - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-23-2012, 05:10 PM
twanster twanster is offline
twanster is starting off with a positive reputation.
Does anyone have any suggestions? I Drove my pickup to work, it fired up just fine. When I started it up to head home, it sounded sluggish, but ran. About 3 miles down the road it shut off. Ended up getting towed. I've replaced the fuel filter and treated the lines with seafoam however it didnt fix it. the fuel pump whines when the key is in the on postion, and my pickup tries to turn over, its as if its not getting fuel. Help me please!!!
Old 07-23-2012, 06:08 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
Have you check the fuel pressure at the fuel rail? This will tell you if the fuel pump is dead (most likely issue).
Old 07-23-2012, 06:45 PM
thanks for the reply monster 4, and this is probably a dumb question, but how do you check the fuel pressure at the fuel rail?
Old 07-23-2012, 06:50 PM
mikeismadness's Avatar
mikeismadness mikeismadness is offline
mikeismadness has a good reputation on FTE.mikeismadness has a good reputation on FTE.mikeismadness has a good reputation on FTE.
Get a fuel pressure gauge and hook It up to the schrader valve on the fuel rail. It will have a black cap that looks like a valve stem cap. Tell us what the pressure is
Old 07-23-2012, 07:48 PM
Monster-4's Avatar
Quote:
What he said. You should have 28-30 psi at idle (also think it's the same for KOEO) and 38-40 at WOT.
Old 07-24-2012, 01:25 PM
right on ill give it a shot thanks
Old 07-24-2012, 01:51 PM
VONxRUBENxLA's Avatar
VONxRUBENxLA VONxRUBENxLA is offline
VONxRUBENxLA is gaining momentum as a positive member of FTE.
u could also hook up a little fuel pressure gauge on there permantly if u feel it necessary
also does anyone know if a scan gauge II can read fuel pressure?
Old 07-24-2012, 02:25 PM
Monster-4's Avatar
SGII cannot read fuel pressure. There is no factory sensor.
2000 3.0 Flare Side. Replaced Pump, Still Not Getting Fuel. Diagnostics? Critterhunter Ranger & B-Series 14 06-17-2015 06:11 PM
when to upgrade the fuel lines? bbf150 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-31-2013 08:49 PM
Need help with 93 F350 1 ton dually with 7.3 International Banks Turbo rockenh1974 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 12-09-2009 11:55 PM
starts cold when warm doesn't Monty06 Bronco II 21 12-10-2004 12:41 AM
Mystery Truck?? 88B_RONC 1961 - 1966 F-100 & Larger F-Series Trucks 5 09-02-2003 09:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
