WILL 08-12 6.7L FORD DIESEL FIT 05 F350 6.0 FRAME
Anybody know if the frames, engine and transmission mounts are in the same spots on the 03-07 and the 08-12? I have an 05 F350 6.0 and thinking about putting the newer 6.7L Ford in it if it will fit. I would use the newer 6R140 transmission. I currently have 4WD. I know I would need the ECM and FICM for the 6.7L.
2013 Ford 6.7L diesel engine in 2005 Ford F350
Can anyone advise if this has been tried or can be done. Putting a 2013 Ford diesel motor in a 2004-2007 Ford with the 6.0L diesel prone to problems or would I be better off to spend the money to fix the problems or just go to a 2013 Dodge 2013 that will fit.
It sounds like it is time to de-stroke your powerstroke.
Destroked - THE Cummins Conversion Company : Home Page
I'm not a salesman, they just make good stuff.
