37s with open diffs is possible with a light foot, but throw lockers into the mix and there is no chance of those shafts surviving the first trail ride. Btw ttb Dana 44s have the exact same weak link as a solid axle Dana 44, the u joint size
What are you going to do about the rear end? its sagging quite a bit
F250 HD springs and 3" block.
I;m wanting a Detroit locker in the rear, and a Detroit true-trac lsd in the front. It uses worm gears instead of clutches.
I could do a Dana 60 wap, but then I'd have to go leaf spring suspension. The whole reason I stayed away from the Dana 60. I wanted to keep the coils, and I knew I could get F250 Dana 44 HD kuckles and convert to 8 lug.
Why couldnt you put the coil buckets on the dana 60 and go that route?
And you could go to a D60, but why do 2 SAS on one truck? I think that with a sterling rear the truck will be plenty tough enough to handle 39.5" unless you're going to tough truck it. Can't wait to see it all daid and done SCRebel.
Well finding a Dana 60 is going to be the hard part. Lol.
I plan to keep the Dana 44 unless it just can't do it. I don't ****** and pull. If CV alxes can handle 38's, I'd hope a Dana 44 solid axle can handle 38's or even 39's.
I run 39.5/15/16.5s super swamper tsls and they are heavier than my buddys 40/18 gumbo mud something or anothers. They aren't light tires and I run a built dana 60 and built sterling 10.25
