7.3L PCV Re-Locate Questions....... - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-10-2003, 10:53 PM
JoeBoost's Avatar
JoeBoost JoeBoost is offline
JoeBoost is starting off with a positive reputation.
Question 7.3L PCV Re-Locate Questions.......
Hello ,
I orignally posted this in the 7.3L forum but had no luck , maybe someone here can help me out....
I did a PCV re-locate this weekend and I have a few questions for someone who knows alittle more about diesel motors than I do ..
The stock system purges the crankcase pressure into the intake tube , right before the turbo. From what I have read , this causes excessive amounts of oil to build up over time in the intercooler , and thus making the intercooler not work as well. What I did was run a hose from the stock PCV breahter adapter on the valve cover to a racing cach can with a breather on it. All in all no issues except it looks like I have a fire under my truck due to the steam comming out of the breather.
My new idea was , to weld a bung in the exhaust and run the PCV to this , so the exhaust would actually help suck the pressure/steam out of the crankcase , as well as no more "smoke" under the truck. Racecars use this type of system, know as a Crankcase Evac system , and as far as I can see , would work on the truck as well.
Anyone have any feedback on this ??????
Old 05-11-2003, 08:14 AM
powerstroker250 powerstroker250 is offline
powerstroker250 is starting off with a positive reputation.
I wonder if the volume of exhaust, especially under boost, would actually suck oil out of the engine.
Les
Old 05-11-2003, 02:18 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Not that I've heard about, supposedly installing it in the exhaust creates a better ring seal, and improves efficiency a little bit. Currently mine just vents to atmosphere out behing the back doors, but I plan on switching it to the exhaust whenever I get the initiative to go weld this bung in.
Old 05-11-2003, 04:45 PM
JoeBoost's Avatar
Thanks for the replies. I just wanted to hear from some other Diesel owners before I went and did this mod.
Thanks again ,
smoking 67 ru67 1967 - 1972 F-100 & Larger F-Series Trucks 23 08-13-2016 06:03 PM
PCV Valve Question hollenjoe 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 8 07-05-2010 10:37 PM
PCV valve/crankcase filter location? JKK 1987 - 1996 F150 & Larger F-Series Trucks 3 03-15-2006 08:49 AM
7.3L PCV Re-Locate Questions ??????? JoeBoost 1999 - 2003 7.3L Power Stroke Diesel 11 05-22-2003 10:56 AM
can a blown head gasket cause too much crankcase pressure? sixx pak Ford Inline Six, 200, 250, 4.9L / 300 6 01-31-2003 02:18 PM
Tags
1999, 2002, 2003, 3l, 7, 73, 73l, crankcase, diesel, ford, obs, pcv, pressure, pvc, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
