F-150 wipers- randomly turns on - Ford Truck Enthusiasts Forums
Old 07-22-2012, 06:52 PM
tuske427's Avatar
tuske427 tuske427 is offline
tuske427 is starting off with a positive reputation.
Hi:
Ok, I can't be the first guy with this happening (and I tried searching with no success) as I drive my truck, every now and again the wipers turn on. Just once. then are off again.
It's a '99 F-150 XLT. Is this the switch? other? Any experience with this little electrical gremlin would be appreciated.
Thanks!!
Old 07-22-2012, 09:23 PM
2001=f150 2001=f150 is offline
2001=f150 is starting off with a positive reputation.
Iv,e seen this a hundred times and its alway been the Multi-funtion Switch. Aka wiper switch, turn sig switch, 4 way flasher switch, dimmer switch.
Old 07-22-2012, 10:59 PM
tuske427's Avatar
OK, I'll replace that. Thanks!!
Old 07-22-2012, 11:17 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Don't mess with the dealer, NAPA carries them and I am sure Rock auto does as well.
Old 07-25-2012, 09:44 PM
tuske427's Avatar
Quote:
good call, thanks!
No intermittent wipers- wipers will not park after using washer?? No cost fix!! phoneman91 1987 - 1996 F150 & Larger F-Series Trucks 50 11-18-2016 10:22 PM
Windshield Wipers Failed Whisk3y 2004 - 2008 F150 2 06-08-2016 03:32 PM
1992 F150 v8: Turn signals turn on the windshield wipers imsorope 1987 - 1996 F150 & Larger F-Series Trucks 1 04-16-2014 12:51 AM
windshield wiper problems 92 Black Nite Electrical Systems/Wiring 4 10-22-2013 07:25 AM
79' F 150 wiper motor issues? Corpsman24 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-12-2012 03:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
