03 Explorer Sport weird AC problem...
I've been searching the forum and can't find anyone having this issue, but if there is, sorry for another post.
Yesterday the AC started acting up, what it does is while were driving, all the sudden the AC will switch from the front vents to the defrost vents for about 20 to 30 seconds, then it will switch back to front vents. The time on front vents is anywhere from about 2-5 minutes, then it switches back to the defrost vent and so on. The air is still cold coming from the defrost vent and the front vent.
Anyone got any idea what might be causing this? Have never had this happen on any vehicle I have owned.
Thank You for any help.
Does it do it sitting still or is when you are accelerating? If when accelerating it sounds like a vacuum leak. check the hoses under the hood for broken lines, and check the vacuum reservoir especially if it's a metal coffee can looking thing look for rust at the bottom...
It does not do it while sitting in park. Where is the vacuum resevoir at?
BTW - I changed the spark plugs yesterday morning and reset the pcm, this started after that.
hink10
09-28-2017 11:38 AM
Salomon Trujillo
07-29-2013 09:20 PM
CraigK
24
08-08-2010 07:43 PM
bolingmike
1997-2006 Expedition & Navigator
07-07-2005 05:54 PM
