Can't lower spare tire.
Ok before getting to much into it my spare tire lock(that thing you need a special tool for) has been removed.
Now for the spare tire. I tried to lower it so I can take apart the trailer wiring connector to check it, But it seems where the tool to lower the spare goes in is stripped out. Now I know about Fords lock and removed that a couple years ago. I have had my spare down a few times since then to lube the winch and parts. I have always just put the tool down the hole and lowered it and raised it, with no problems. This time it just spins, I then removed that plastic tube, but just can't get around the spare. I also tried a 1/2 extention and it just spins.
Do I just cut the cable, then replace the whole thing? No one else has removed my spare but me, I am wondering if someone tried to steal my spare.
Last edited by IslandBlueV10; 07-21-2012 at 06:38 PM. Reason: Updated the Information.
On trailer lights start with checking the fuses on the panel under the hood.
There is a parallel thread about the spare wheel winch with special tool. There is procedure when you can tap 14 mm or so socket over and use that to lower the wheel. I had that lock with no "key" on my new purchased F250 and PO cut the cable. The lock comes out with some persuasion as all it holds is spring-lock washer.
I checked the fuses under the steering wheel, but will check under hood.
As for the spare tire. I already removed that lock years ago. But it seems that the spot where that lock went into has stripped out. My tire tool just twists inside and won't lower the spare.
If it won't crank down, there's nothing else you can do but cut it and replace the winch. You might even be able to take it apart and repair it. Drill out the big rivets and it splits in two. I had mine apart when the cable birdnested inside it and wouldn't go up or down. Had I not beat the thing with a sledge out of frustration, I could've replaced the cable for a few bucks and bolted it back together instead of paying $95ish for a new one.
Thanks for the suggestions, I am going to the junk yard tomorrow to look for another tire winch. This way I can get a good look at it, before I cut mine. I still can't see how mine stripped. I can't get my arm in their to feel where the tool goes into. Using a flashlight it looks like the end is all messed up. I know when I removed my lock everything was fine. Then last year I replaced my spare tire due to the age of the tire, and to match the size of the rest of the tires. Like I said I have not had a problem before and always cleaned and lubed it while I had the tire out.
I had a good junk yard day. I found the tire winch off of a 2007 F-250. Sad thing this truck just came in saturday, it had the 5.4L. This truck was perfect except someone started to tear the motor down, got 1 head off then quit. The body was straight, everything their. But the tires & wheels, and the bed was being salvaged while I was getting the winch off. If I had the money and got to it this morning I would have bought the whole truck and put a motor into it. It is to bad they are parting out such a perfect looking truck.
I will replace my tire winch tonight or in the morning.
Here is what I found:
<a href="http://s1066.photobucket.com/albums/u420/IslandBlueV10/Autos/?action=view&current=IM000534640x480.jpg" target="_blank"><img src="http://i1066.photobucket.com/albums/u420/IslandBlueV10/Autos/IM000534640x480.jpg" border="0" alt="Photobucket"></a>
Just glad I found this now instead of being on the side of the road. This is as bad as finding out that I had that lock in there.
Mine was exactly the same when I got it. Someone had cut the cable as well. I bought a replacement off craigslist from a truck that had been converted for railway duty. After I got it home, I discovered that it was different than mine (from an 08 maybe?) and the mounting holes were different. Long story short, I ended up opening them both up and using the 01 case and the 08 internals. Works just fine now and accepts a standard 3/8 extension and ratchet for winching.
96_F250_Deezal
1999 to 2016 Super Duty
20
12-22-2023 03:26 PM
Rasm616
10-27-2017 03:15 PM
