Down a litre
Down a litre
I`ve got a few friends with 6.4s and we all do our oil changes at the about the same time. Non of us have done the ccv reroute, mod, and we are constantly looking at the intake and cleaning it. One of us decided to lower our oil to 1 litre less than what it says to put in ( reads just below the half point on the dip stick) Guess what,, no blow by from the ccv at all and no change in engine temps, turbo temps, oil temps.
Would like to here comments,, is there too much oil being put into these engines.
One Quart/Litre Down:
My 6.4 now has 60000 miles/100000 kms on it. From the first oil change, I have used 14 US quarts of Mobil Delvac 5W-40 Synthetic oil.
I have three reasons for this. Putting in 15 US quarts of oil is assuming that the crankcase is empty and when oil is added it takes 20 minurtes to get an accurate reading of the oil level on absolute level ground. Ford techs won't wait that long and shop floors have a slope for drainage. It can result in being over full. I understand when there is too much oil is in the crankcase, the oil will foam. Secondly it is possible that fuel is diluting the oil and filling the crankcase. Thirdly Ford has added the over filled oil quantity to the message center. Your truck should have the module recalibration under the Customer Satisfaction Program 11B23 which will protect you and your truck from this condition. The engine software is now capable of detecting elevated crankcase oil levels and will set a code and turn on the check engine light. If you have not gotten this update you should
For my peace of mind and to avoid the over full oil condition, the 14 US quart quantity addresses all of my concerns above.
jthussey
6.7L Power Stroke Diesel
17
04-26-2019 06:58 PM
