Flex wiring harness
Flex wiring harness
I recently purchased a 2012 Flex SEL without the nice navigation system. I'm kind of wanting it now though and wonder if Ford uses the same wiring harness in all the Flex models. If so, I'm guessing there is a possibility of finding a wrecked Flex and swapping some components onto mine.
So, that's my question: Does anyone know if the SEL and Limited Flex models use the same wiring harness?
Thanks
Thanks
There is probably a plug there in the wire harness. You need to get ford parts to pull up the picture of the parts. " probably not to big a chance of getting one from a wrecked one soon, and you need to know info but a salesman might be able to get you a lot of free info about it if you ask him. The real deal is will the puter need a flash to get the driver for it.
