Help!! PCV valve
Help!! PCV valve
OK, Some of you are going to think this is a dumb question but I have to ask it.
I believe my truck is missing its pcv valve so I need to know exactly where it is located. According to my manual, it should be on the oil filler spout on the drivers side and the hose goes to my air filter, is this correct? If that's the case, then it is missing.
Dang, I guess including my engine might have helped a little. It's got the 460 in it, I checked the hose going from the oil filler hole to the air filter and there is nothing there but hose.
I also managed to stop by NAPA on the way home from town so I could get a look at one and according to their parts book the pcv valve for this engine is threaded. I've never seen one like that before so i'm not sure where to start looking. Anyone out there know it might be?
Passenger side valve cover: Where is the Location of PCV Valve on 1997 ford F-250 HD with 7.5L
Yes, there should be a vacuum hose running to it.
66flareside
13
01-25-2009 07:26 PM
Proxymatic
05-14-2008 10:01 AM
djmac
01-13-2004 09:15 AM
