All map and baro codes. Major engine oil loss. A ton of oil comin from tail pipe. This sounds like a turbo issue. Just need some input from som1 that knows more about em. Thanx guys
Only thing I can think of right now is those sensor are having an issue because of the excessive oil consumption.
So solve that and those should clear up.
Turbos or rings and valve issues. Have you done a compression test?
No,no comp test. If those turbos are oiled just like a 6.0,then id say that seal is busted in there. I built a 6.0 4 a rich kid. This thing was producing so much horsies the hot side fan on the turbo twisted off!
