AC Compressor repair cost - Ford Truck Enthusiasts Forums
Old 07-20-2012, 10:48 AM
Gautiergator Gautiergator is offline
Gautiergator is starting off with a positive reputation.
The AC Compressor on my 2003 Ford F150 V6 2wd is leaking and I have an out of work mechanic that is going to replace it for me. I bought the new compressor and 134A already. He said he would do it for whatever I wanted to pay him. What would be a reasonable amount to pay for this job? I don't mind overpaying but I definitely don't want to under pay him.
Old 07-20-2012, 02:24 PM
dbreckman dbreckman is offline
dbreckman is starting off with a positive reputation.
That depends on the going labor rate in your area. For even a novice with the right tools and parts on hand this is a 2 hour job tops.
Old 07-20-2012, 05:23 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
does he have the vacuum pump ? and he knows how to do a proper charge / oil ? Dealer will charge you $100. hour. Guy working on his own might be $25-30 ?
Old 07-20-2012, 07:07 PM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
If you can save on much of the labor thats great, but you need more parts.
You will need to make sure you have a seal kit, a flush kit, flushing agent, manifold gauge set, possibly a new condenser, a new orifice tube, new accumulator, etc.
Whenever you have a compressor death, you need to flush the whole system out, and replace everything that can't be flushed. Otherwise your new compressor will fail again.
Most of the manifold hose sets contain a small muffler than cannot be flushed, if yours does, replace the hose assembly. Some condensers don't flush that well, it should be replaced. The orifice tube MUST be replaced, and should be replaced every time eh system is opened regardless of why the system is being serviced. The accumulator must also be replaced, it cannot be flushed.
Flush out any remaining hoses, and flush the evaporator.
I'm assuming your mechanic has most if not all of the needed tools.
Whether he is a mechanic or not, make sure he is licensed to service AC systems before you let him touch your car. Otherwise he may do more harm that good, and you will be responsible for it.
Old 07-20-2012, 07:33 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
Take it to a dealer and get an estimate of the repair cost, parts and labor. Then decide what is fair to pay the technician based on the same quoted labor repair from him if he is a professional qualified tech out of work he should get at least 25-35 percent.
At my dealership an AC diagnostic is only 45.00.
Old 07-20-2012, 08:27 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
All of that is only necessary if the compressor came apart internally and contaminated the system. OP said his is only leaking. Alldata has that job at 1.4 hrs plus 1.4 hrs to evacuate and charge the system. I would pay him at least $100 provided he has the equipment to pull a vacuum on the system and charge it properly. If not, $50 will be good then take it to an a/c shop to get charged.
2006 Expedition AC not working Dave_Expe Cooling, Heating, Ventilation & A/C 6 08-31-2016 03:50 PM
2007 Expedition A/C Clutch not engaging Netroamer 2007 - 2014 Expedition & Navigator 0 06-28-2016 10:44 PM
FS10 AC compressors that aren't from China? GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 0 04-16-2015 06:59 PM
Need belt help! LeeLeadingham 1997-2006 Expedition & Navigator 7 07-30-2011 11:29 PM
Removing AC Compressor wagoner.josh 1987 - 1996 F150 & Larger F-Series Trucks 8 09-27-2009 11:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
