Parting Out 1979 F350 4x4 Lariat and more!
Category: Accessories
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude
Item Condition: CT
Shipping Information: Item can be shipped
Tweeder-2 or 4wd?If 4wd...5 3/4" or 8 3/4" intermediate housing?
Which engine?What year?
Lrdvdr-Bed is shot on one.Give me a dimension on how big you'd like the cutout.
Big enough to splice it in to a new bed and retain the mounting points for the plastic and the fuel door. I'd need a big enough section to add a fuel door to a bed without one. I'd like the plastic and the door as well. If I had to guess, I'd say 4-5" all around the opening would be sufficient.
Tanman-Bronco or p/u hinges?
Hey 351coupe, its a 79 F150 Ranger XLT 4x4 with a 400. Not sure of the shaft length but I do know that a 2wd tranny wont work because the output shaft is to short. Hopefully that helps a little.
Lrdvdr-The bed is so rotted,I can't even cut a couple of inches around door.It's rusted right to it.Unbelievable.
Elk-The highboy mid driveshaft,I assume?
The only ones I have were from 4 speed trucks.
#29
I'd still take what's there, if you have the fuel door and the plastic that goes inside. I can use it to form up the part I need easier than going back and forth to the truck I have.
