Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 07-20-2012, 12:06 AM
efxengr efxengr is offline
Garage is empty, add now
efxengr is starting off with a positive reputation.
A/C, fan clutch? my numbers are.....
07 Expedition w/aux rear air, 172,000 mi, well maintained.
92 deg days in south Florida I'm noticing A/C feels warm at idle but not bad under speed so I took some readings:
Engine off: 90 psi low & high, Amb 84 deg (Gauge Manifold is Mastercool brass)
doors open, a/c on max cool, fan high:
Speed 1500 rpm
Amb. 84F
Low 20psi
High 212psi
Vent Temp 58F
So I added 134a until I got the following:
Speed 1700 rpm
Amb 84F
Low 30 psi
High 275 psi
Vent temp 55F
@idle:
Low 40 psi
High 250 psi
Vent temp 59F
While @ idle or slightly higher I heard the fan clutch kick in (and wind noise), immediately the head pressure dropped to about 190-200psi, low dropped to 30 psi, and vent temp started dropping to 50F and below (48F) but didnt stay more than a few minutes.
Engine off, new high/low pressure is 96F w/ amb of 83F.
At ilde it almost looks slightly over charged. Shouldnt the fan clutch remain on at idle? How can I check or is it better to just replace? Not sure what cycles it, engine coolant temp? refrigerant head pressure? is there a way to test? IT was spinning the whole time while taking readings but there was a noticable change when it kicked in.
Thanks for any thoughts.
  #2 (permalink)
Old 07-20-2012, 06:03 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Controlled by a thermostat built into the clutch. What engine?
__________________
Speed is a question of money. How fast "CAN" you go?
  #3 (permalink)
Old 07-20-2012, 06:16 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
'07 Expeditions are all 5.4 V8.
-- Chuck
  #4 (permalink)
Old 07-20-2012, 06:25 AM
Engine is 5.4L all stock, all original except for one new plug coil, idler pulley, minor misc. A/C control panel was replaced under warranty at 35,000 mi.
  #5 (permalink)
Old 07-22-2012, 07:01 AM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
Try using a fan to push air accross the condenser to check the pressures. I think the new models use electonically controled fans. My 08 F150 had a pair of wires going to the fan drive. The clutch fan may be doing what it is designed to do.
__________________
2013 Explorer Limited
87 Ranger, XLT
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
