2003 F-150 brake issues
I have a 2003 F-150 supercrew 4x4, was having problems with the brake pedal going to the floor, had replaced the front calipers, master cylinder and the brake booster. I have blead everything out including the rear calipers even though I didn`t touch them, the truck stops but the pedal isn`t what it used to be, even when the truck is off the pedal has a tendency to go down, there is nothing leaking and not losing fluid, don`t know what else to do?
Bluegrass 7
Thanks for that info didn`t know that the rod could be adjusted.I took the master off unscrewed it so that the master is about an 1/8" off the booster before you tighten the nuts up and that worked, the pedal is way up high and doesn`t go to the floor. That`s why I love these forums, you find out things you wouldn`t think of. Thanks again.
Bowersdiesel
08-26-2018 08:15 AM
1986stepsidef150
07-22-2012 09:45 PM
George84
11-16-2010 05:42 PM
jenkinsj
06-20-2008 08:08 AM
