429CJ
429CJ
Category: Engine - Complete Motors
Price: $3500
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): '06+ Civic/CSX, Prelude
Item Condition: LA
Engine: Part suitable for gas truck
The engine has less than 3,000 miles, transmission 25,000 miles.
429 CJ 4-bolt short block @ .030 with 10-to-1 forged pistons. The crankshaft is .010-.010. The heads are D2OE with screw-in studs and stock rockers with push rod guides. The cam, carburetor, and manifold are Edelbrock. Dura spark with MSD Blaster 2 coil. CJ finned valve covers. Viscous clutch fan, Saginaw power steering pump and steering box. All mounts and brackets are stock Ford. Also Dyno max headers.
The transmission is custom built with the wide ratio planetary and shift kit. The converter is stock stall with the nose turned down to mate to the CJ crankshaft.
The engine is in the truck so that anyone interested can drive it and do any checking out they want. You will know that this is no junk. I can have the package out in 1 day. Interested parties will have to come and pick it up.
Also the front brakes, drums are going. The “I” beams have bronze kingpins and springs are going. Front sway bar included. This entire setup will “bolt in” to any 65 to 79 F-100.
I am located in the New Orleans area.
$3500.00 takes all. Kenny Nunez, 504 469 2320,504 427 6905
johnson2007
23
05-21-2014 11:42 AM
RapidRuss
08-19-2006 07:14 AM
Flash
04-11-2005 10:44 PM
builtfordtough88
11-04-2004 11:09 PM
