Coolant flush question
I bought a 2003 f-350 6.0 about a month ago and I have been doing some maintenance to the truck the other day I started to do a coolant flush and drained the coolant and filled it up with distilled water let the truck run for 30 mins and drain it 3 times with the heater on and it was coming out clear water on the third time that's when I realized I was an (dumb a**) cause the thermostat wasn't opening to clean the whole system so I went and bought 15 more gallons of distilled water filled the coolant system up again and drove the truck for 45 mins for the thermostat to open up and circulate everything real good I drained it and it was pretty dirty goldish brown more brown then gold so I did the whole cycle one more time and drained it it was cleaner but not clear distilled water not thinking I figured that was good enough went ahead and installed my coolant filter and filled the system up with 3 1/2 gallons of ford gold antifreeze do you think this is ok even that I didnt flush it until the distilled water was clear coming out or should I just say I wasted 150 dollars due to stupidity and flush the whole system again
Spend a bit more and get a filter on it.
When you change the filter each time just
unscrew it from the mount and put the coolant that
is in the filter in a clear container and look at what is there.
then cut the canister open and have a look at the
filter media for grit and crap. If you see a lot of junk
and then re-flush with Restore and Restore+.
Use the info in the tech folder for a how to.
Do you have some thing to keep an eye on the deltas?
If not then you want some thing like the ScanGuage II
and program in the X-guages. Other things will work
it just the SGII is less money, easy and does a good job.
Sean
Sean
Last edited by Yahiko; 07-22-2012 at 05:06 PM. Reason: Spelling and missed something
even driving till thermostat opens dont really circulate even at 190* thermostat is only cracked open
Dont sound like it too dirty though
but next time pull the thermostat out set truck to high idel or 1100rpm for an hour with cleaners in it
Iv done Both ways pulling thermostat was best also drain the Block drains
You need 3.5 Gallons Full Strength Coolant with all the water the 6.0L cooling system holds even when block drains are pulled that will get a touch strong 50/50mix
If you are in question they sell a cheap Hydrometer to check the coolant strength like 5 bucks at auto parts store to test with
Danner717
01-13-2016 01:52 AM
cabloom300
01-17-2014 06:29 PM
hawkeyestoob
10-19-2012 10:48 PM
