1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
rad support mounting?
Old 07-19-2012, 08:42 AM
mark63uni's Avatar
mark63uni
mark63uni is offline
I'm finally in the process of getting my truck back together, but I cant remember if there was a bushing of any sort between the frame and rad support. I dont see anything on my parts shelf... but I feel like there should be something there?
Old 07-19-2012, 10:11 AM
Buzz44's Avatar
Buzz44
Buzz44 is offline
According to the service manual there should be a large bolt with a large washer. Next is a rubber pad this pad will be inside of the core or radiator support under the large washer. Next under the frame or the raised sections that the support sits on is a nut. This nut is a large square with a metal insert surrounded by rubber with a raised round center around the metal inside threads. This is followed by a large washer and another nut. This is if you have a conventional cab. If you have an integral cab add a small spring on the inside of the core support and take away the square rubber pad. The spacing on the bolt and spring heigth should be 1.28 measured from bottom of the bolt head to floor of the core support.
Old 07-25-2012, 02:05 PM
mark63uni's Avatar
mark63uni
Perfect, thanks for the info. I think I have something that sounds like that laying around.
Old 07-26-2012, 09:26 PM
Howell05's Avatar
Howell05
Howell05 is offline
if someone needed those rubber supports plus all the hardware where would one find them? cant seem to find anything in my parts books. i guess im looking for the official name of the mount.
Old 07-31-2012, 11:12 AM
Buzz44's Avatar
Buzz44
Buzz44 is offline
This might help you a little.
http://www.flickr.com/photos/vic-63-65/6769433115/http://www.flickr.com/photos/vic-63-65/6769433115/ by http://www.flickr.com/people/vic-63-65/, on Flickr
Old 07-31-2012, 07:16 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Can't seem to find anything in my parts books.
Shown in the frame section.
1973/79 Ford Light Truck Parts Catalog / Illustration Section 50 ~ Pages 6 & 8.
1964/72 Ford Truck Parts Catalog / Illustration Section 50 ~ Pages 20 & 21.
Old 08-08-2012, 02:46 PM
mark63uni's Avatar
mark63uni
Thanks again, had to do some micky mouse'n but it's on there!
needshave
12-16-2018 08:42 PM
tbm3fan
09-24-2008 08:41 PM
Tedybear
06-20-2008 07:26 PM
JefflovesF250s
09-04-2007 07:42 PM
Quick Reply: rad support mounting?
