Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 07-19-2012, 08:42 AM
mark63uni's Avatar
mark63uni mark63uni is offline
Garage is empty, add now
mark63uni is starting off with a positive reputation.
rad support mounting?
I'm finally in the process of getting my truck back together, but I cant remember if there was a bushing of any sort between the frame and rad support. I dont see anything on my parts shelf... but I feel like there should be something there?
  #2 (permalink)
Old 07-19-2012, 10:11 AM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 is gaining momentum as a positive member of FTE.Buzz44 is gaining momentum as a positive member of FTE.
According to the service manual there should be a large bolt with a large washer. Next is a rubber pad this pad will be inside of the core or radiator support under the large washer. Next under the frame or the raised sections that the support sits on is a nut. This nut is a large square with a metal insert surrounded by rubber with a raised round center around the metal inside threads. This is followed by a large washer and another nut. This is if you have a conventional cab. If you have an integral cab add a small spring on the inside of the core support and take away the square rubber pad. The spacing on the bolt and spring heigth should be 1.28 measured from bottom of the bolt head to floor of the core support.
__________________
1965 F100 4x4 for fun. Name Gentelman Jim
1963 F250 4x4 for restore. Name Beast
1998 F150 4x4 for daily use. Name Birthday Boy
2001 Ford 4x4 Explorer Sport Trac (nice but sucks on MPG its underpowered)
Vic by the way.
  #3 (permalink)
Old 07-25-2012, 02:05 PM
mark63uni's Avatar
Perfect, thanks for the info. I think I have something that sounds like that laying around.
  #4 (permalink)
Old 07-26-2012, 09:26 PM
Howell05 Howell05 is offline
1979 Ford F-150
Howell05 is starting off with a positive reputation.
if someone needed those rubber supports plus all the hardware where would one find them? cant seem to find anything in my parts books. i guess im looking for the official name of the mount.
  #5 (permalink)
Old 07-31-2012, 11:12 AM
Buzz44's Avatar
Quote:
This might help you a little.
Click the image to open in full size.
truck stuff by HiBoy63-65, on Flickr
__________________
Vic by the way.
  #6 (permalink)
Old 07-31-2012, 07:16 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Can't seem to find anything in my parts books.
Shown in the frame section.
1973/79 Ford Light Truck Parts Catalog / Illustration Section 50 ~ Pages 6 & 8.
1964/72 Ford Truck Parts Catalog / Illustration Section 50 ~ Pages 20 & 21.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #7 (permalink)
Old 08-08-2012, 02:46 PM
mark63uni's Avatar
Thanks again, had to do some micky mouse'n but it's on there!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
