Converting to SD VC gaskets, UVCH, and exterior VCH
Old 07-18-2012, 02:54 PM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
Question Converting to SD VC gaskets, UVCH, and exterior VCH
If I don't want to buy Dorman parts, what are my options for parts?
Old 07-18-2012, 04:31 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
I think I would get new Ford gaskets and UVCH's. Then find an SD harness in the JY and take the pigtails off of it, solder it up and go.
EDIT: Then again, I guess you could probably get those pigtails from Ford also.
Old 07-18-2012, 05:05 PM
fordpride's Avatar
fordpride
fordpride is offline
When i swapped to the SD UVCH I used the Dorman. They have been on over two years with out any issues
Old 07-18-2012, 06:05 PM
Talyn's Avatar
Talyn
Talyn is offline
Dorman parts are just hit or miss if you ask me.
Old 07-18-2012, 07:59 PM
blageurt's Avatar
blageurt
blageurt is offline
My vote is for international or Ford OEM ...heat shrink and solder everything and be mindful of the clip Vibe associated with the early harnesses
DTS Articles - 7.3L UVC Harness Retainer Clips
https://www.ford-trucks.com/forums/7...ml#post6639153
Old 07-18-2012, 09:33 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Riff Raff has everything you need IIRC.
Old 07-18-2012, 09:52 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Is there an advantage to switching to the SD uvch?
Old 07-18-2012, 09:57 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Some think so. I don't really see a disadvantage. But then again I don't see a real advantage either.
Old 07-18-2012, 10:13 PM
blageurt's Avatar
blageurt
blageurt is offline
In my opinion , If you an solder and Heat shrink properly then yes .....if you want plug and play...... I would retain stock configuration and replace everything per side , carefully inspecting the VC gaskets for burn through......
Old 07-18-2012, 11:12 PM
cowmilker08
I thought Felpro made these parts but I could only find the gasket.
I am converting to SD parts because the GP pins are larger and they won't burn up every six months to a year like my OBS wiring does.
My one and only experience with dorman UVCH was an epic fail. I bought what I thought was felpro, and you could see the differences in quality with the naked eye.
Old 07-19-2012, 08:13 AM
Talyn's Avatar
Talyn
Talyn is offline
Yes he does.
Old 07-19-2012, 03:08 PM
strokin'_tatsch
The SD does use larger GP pins, so it would be an upgrade to get away from burnt harnesses, but I have had to replace burnt SD harnesses before along with repair connectors that weren't tight enough to get a proper connection under the valve cover.
So far, I haven't had to replace any burnt UVCH's on my truck. Not sure if it's because of good new glow plugs or what, but they've yet to fail me. Now as soon as I say that, I'm sure I'll be replacing them before long. LOL
Old 07-19-2012, 05:06 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Yep!.........
Old 07-20-2012, 12:07 PM
cowmilker08
I put new Ford GP in when I fixed the connections last time.
I am also planning on putting a fuse in line with each GP as well.
So basically there are no off-brand parts available other than Dorman?
(Or Felpro for the gaskets only)
Old 07-20-2012, 01:18 PM
BadDogPSD's Avatar
BadDogPSD
BadDogPSD is offline
If someone needs some SD UVCH's send me a PM, I have a set that I bought by accident and I'll make you a very good deal!
Quick Reply: Converting to SD VC gaskets, UVCH, and exterior VCH
