sounds like rumble strips??? help - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 07-18-2012, 01:42 PM
svaughan svaughan is offline
svaughan is starting off with a positive reputation.
I have an 01 expy with 83K on it. when I'm getting on the highway and get up to cruising speed i hear a noise that sounds like im running over rumble strips from the rear of my truck when it drops into low gear?
I am totally illiterate when it comes to working on cars. Can anyone help me?
I love this truck but it's turning into a money pit and I don't want to get ripped off on repairs.
Old 07-18-2012, 09:18 PM
thecardoc thecardoc is offline
thecardoc is starting off with a positive reputation.
If you are on the highway at cruising and your truck drops to low gear you have some very serious problem and are lucky you did not loose your motor due to very excessively high RPM
Now if you mean shifts to high gear or most likely converter lockup mode you may have a converter shutter. This can some times be resolved by a complete fluid change and an additive like Dr. tranny Shutter stop.
Old 07-19-2012, 12:51 PM
no, it makes the noise when the rpms drop down, when it goes into overdrive.
Old 07-19-2012, 05:29 PM
rattosh51's Avatar
rattosh51 rattosh51 is offline
rattosh51 is starting off with a positive reputation.
Still sounds like it might be tranny fluid change time...the Expy's are known to start "shuddering" when the fluid gets dirty or used up...check your tranny fluid...it's probably never been done. Believe it's supposed to be at 60K miles.
Old 07-19-2012, 06:55 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
+1 on the tranny fluid change time.
(Do a search on here and you will find a number of posts on how to replace ALL (19 quarts?) of the tranny fluid.)
Old 07-19-2012, 08:35 PM
5.4T's Avatar
5.4T 5.4T is offline
5.4T has a very good reputation on FTE.5.4T has a very good reputation on FTE.5.4T has a very good reputation on FTE.
i have a question, if you remove the fluid from the torque converter how the heck do you put it back???
Old 07-20-2012, 12:39 AM
dirtslmfan_25 dirtslmfan_25 is offline
dirtslmfan_25 is starting off with a positive reputation.
My 02 with 118,000 was doing the same thing. I don't want to give you bad news, but I'm willing to bet you need a rebuild. I was going to do a fluid change and add the Lucas oil stuff, but decided to call my brother-in-law that own a trans shop. That is a tell-tale sign that there is major problems. He said that if I wanted to baby it for a while and just drive it locally, it might have lasted for a while. I was going on a family vacation in the mountains and couldn't risk breaking down in the middle of you got perty lips KY, or TN and be at the mercy of what someone might try to charge me or pay for a 500 mile tow. Fortunately for me he only charged me his cost, with door to door service.
Old 07-20-2012, 06:52 AM
i had the tranny flushed and cleaned last week. there was a big difference in the smoothness between gears, especially when I would step on it. it used to make a loud thud noise when it downgeared, but not anymore...but it still makes the rumble strip noise but only when Im on the highway and it goes into overdrive. its in the shop right now so i'm expecting a call from the service dept today telling me its gonna cost $1000.
I just dropped $2500 on a new head gasket, serpentine belt, and front pads and turned down rotors.
Old 07-20-2012, 01:53 PM
just got off phone with ford dealership. They checked everything. tranny, drivetrain, suspension front and back, all working properly...road tested it and got the noise, ran it while on rack and saw that front passenger tire shimmys aroung 65 to 70 miles per hour. found that rim is a little bent and tire is cupped. told me to drive on it for another 4 to 5k miles that it might conform to road.
i am happy that it won't cost anything but are they correct?
Old 07-20-2012, 03:21 PM
bowesmobile bowesmobile is offline
bowesmobile is starting off with a positive reputation.
Yeah, that sounds like it could be it. Sometimes its really hard to describe noises online.
Old 07-22-2012, 12:19 PM
Mark Surks Mark Surks is offline
Mark Surks is starting off with a positive reputation.
Sounds like it might be the real hub bearing on either or both sides. Remember the days when the wheel bearing was a simple bearing that you packed with grease? Those days are over. Now it is a bulky electronic device costing nearly $500. It ties into the ABS system.
I replaced mine at the tire shop i use (I thought the noise was a tire issue). They showed me how the bearing was not spinning frictionlessly (smoothly)
Old 07-24-2012, 12:58 PM
minitrk's Avatar
minitrk minitrk is offline
minitrk is starting off with a positive reputation.
Had this same problem a couple years ago, was told by several people and shops "time for a torque converter and rebuild". well being cheap I did research and found a trans shop that said something VERY VERY similar to this...
Quote:
I (the trans shop) did exactly this, and solved all my issues. That Dr. tranny stuff works. Never thought a tranny shop would NOT sell a rebuild. Total service charge under $175.00, Total rebuild with converter $2,500.00. Yeah, Ill try the cheap way first!
1999 f250 please help!! Possible issue with a driveline part? Braydenv57 1999 - 2003 7.3L Power Stroke Diesel 6 08-30-2016 06:36 PM
RUMBLE STRIP NOISE THAT GOES AWAY WHEN BRAKING OR TURNING topdawg82 1997-2006 Expedition & Navigator 1 07-03-2014 11:50 AM
Rumble vibration while braking... 04X 1999 to 2016 Super Duty 14 03-20-2012 09:24 AM
1994 f-150 300 straight 6, truck shakes but only at a specific time gvfd107 1987 - 1996 F150 & Larger F-Series Trucks 21 12-19-2011 08:16 AM
Rumbling in drivetrain upon deceleration jspringator Excursion - King of SUVs 6 11-03-2011 03:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
