Governed R.P.M.
Somewhere on the Old Car Manual Project Carburetor Manuals - The Old Car Manual Project
there is a manual for governed carbs. I always assumed the desired RPM was set by the throttle cable? Not fixed. But on a pumper I could see it being at a specific RPM.
Reading from a 1938 version of The Ford V8 Cars and Trucks Service Manual The Norman W. Henley Publishing Co. page 175.
The standard governor 40-6850B1 is factory set for 2500 rpm. The speed may be adjusted anywhere between 2250 to 2750 rpm.
This would be the 85 HP engine they're talking about.
So if you really want to baby the truck, figure out your engine speed using a gear ratio calculator and drive accordingly.
Governed R.P.M.
Does it do that regardless of load? In other words, will it run faster empty than when loaded? Sounds as though it wants to fall back up on the torque curve. (The torque curve probably falls off after 2500.)
mr.precision
1947 and Older Ford Trucks
01-02-2016 09:05 AM
Macrobb
13
06-21-2014 01:06 AM
bryanswens
07-07-2009 01:30 AM
Trenthomstad
08-19-2007 09:34 PM
