Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 07-18-2012, 09:19 AM
OnlyAGeologist OnlyAGeologist is offline
1959 Ford F-100
OnlyAGeologist is starting off with a positive reputation.
223 6cyl rebuild question
I have a 1959 F100 with the 223 6cyl I bought last year, PO said it had had its engine worked over previously. How can I easily tell if the engine needs to be rebuilt?
  #2 (permalink)
Old 07-18-2012, 09:56 AM
GB SISSON's Avatar
GB SISSON GB SISSON is online now
Garage is empty, add now
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Do a compression test to check the top end. If you haven't done this before, try youtube. Seems there's lots of instructional videos there. Is there blue smoke? How about blowby? Remove the oil filler cap while it's running. Does it blow out oil and have pressure? Now thread in a mechanical oil pressure gauge in place of the oil pressure light sender. With it warmed up, see what the OP is. The factory service manual will have the specs, but without looking, 15 psi at idle should be okay. I have one truck that idles at about 5 psi and it still has some life in it..... Oh, and welcome to the fridge group. And you happened to get the best year , 1959!
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
