Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-17-2012, 10:06 PM
RUN4CVR's Avatar
RUN4CVR RUN4CVR is offline
Garage is empty, add now
RUN4CVR is starting off with a positive reputation.
My 50 Pontiac tail light install in 57-60 F100
Hey everyone this is what I came up with to install 50 Pontiac tail lights in my now 57 F100 ( see pics).
I used the OE tail light lense mount and cut some slots for the new tail light. I will fine tune this setup with some different springs and screws to pull it in tighter and I will cut the back off the OE assembly to allow the Pontiac tail lights wiring to go through let me know what you think I just didn't want to drill all the way through the box or have any hardware showing inside the bed.
I was going to do this in the bed ( see holes and I still might) but thought I would try this way first
Thanks
Jeff
Click the image to open in full size.Click the image to open in full size.
  #2 (permalink)
Old 07-17-2012, 11:38 PM
59 shorty's Avatar
59 shorty 59 shorty is offline
59 shorty is starting off with a positive reputation.
Works for me. Looks good but not over the top. I like it.
  #3 (permalink)
Old 07-22-2012, 02:43 PM
fast58's Avatar
fast58 fast58 is offline
fast58 is starting off with a positive reputation.
Kyle Brazier
It looks good. I like it.
__________________
http://www.ford-trucks.com/forums/im...ine=1324186537
1958 Ford F-100. 351 W .030 over and Speed Pro flat top pistons, Comp Cams 224/226, World Windsor Sr. heads, Edelbrock Performer intake, Holley 750 carb, Roller rocker arms, Proform one-wire distributor, MSD 6-AL ignition.
  #4 (permalink)
Old 07-31-2012, 08:43 PM
2losteve 2losteve is offline
2losteve is starting off with a positive reputation.
2losteve 2losteve 2losteve
Me too!
__________________
'56 F-100 - on the road 12 yrs
'57 F-100 - waiting
'54 Chev sedan del - in construction
'71 C-10 daily driver
'65 Riviera
'08 Roadglide
  #5 (permalink)
Old 08-01-2012, 02:09 AM
walkee's Avatar
walkee walkee is offline
walkee is starting off with a positive reputation.
Hey Jeff,
good info just in time for me. Never had the "turn-in" on my mind. Just grabbed me a set of Bob Drake´s, too and looking forward to fit them soon.
Thanks, Tom
__________________
Tom
1960 F100 /400/C6
  #6 (permalink)
Old 08-17-2012, 02:57 AM
walkee's Avatar
Jeff,
plz tell me are the pics with the original taillight body underneath and is this the final position of the taillight ? Did you use the rubber gaskets ?
Seems I can look a bit "behind" the chrome ring. I´m in the process of fitting my 50 pontiacs and I want them a bit deeper down the opening. The bulb housing of the pontiacs seems to clear the stake pocket, guess I´ll have to cut the edge of the rubber gaskets ....
Thanks, Tom
__________________
Tom
1960 F100 /400/C6
  #7 (permalink)
Old 08-17-2012, 03:32 AM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Nice!! I assume the Poncho lights are re-pops? Where do you get them?
  #8 (permalink)
Old 08-18-2012, 03:37 PM
RUN4CVR's Avatar
Quote:
Originally Posted by walkee View Post
Jeff,
Thanks, Tom
Yes I used the OE tail light assembly and cut the bulb socket off the back and I used the rubber gasket as well it helps fill in around the light. I just didnt want to drill or mount all the way through the stake pocket and have hardware showing inside the bed.
The pontiac lights were bought from Speedway good price and have glass lenses
Thanks
Jeff
  #9 (permalink)
Old 09-02-2012, 12:58 PM
walkee's Avatar
Thanks Jeff ....
Would you mind when I show you and everyone interested my solution ?
I removed the whole OE taillight and did some cutting on the taillight mount, went the same way with long holes and springs over attaching bolts.
The new 50´s taillight fits without touching the stake pocket and sits deep inside the opening. I used the included rubber gaskets but cut the edge a bit for a better fit.
The first pic shows the taillight mount after cutting and some touch-up, second shows taillight in place.
Thanks, Tom
__________________
Tom
1960 F100 /400/C6
  #10 (permalink)
Old 09-02-2012, 01:29 PM
RUN4CVR's Avatar
Tom,
thats what started to do and I did the OE light first and used it as a templet to mark and drill my holes in the bed as you can see in my first pics still a work in progress
Thanks for posting pics
Jeff
  #11 (permalink)
Old 09-02-2012, 07:14 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Thanks Jeff ....
Thanks, Tom
I'm not usually taken by the fancy stuff but that is a very nice upgrade!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
