How does the through radiator transimission cooler work?
Old 07-17-2012, 08:14 PM
mrad's Avatar
mrad
mrad is offline
If my coolant temp runs around 185, how does the the radiator help to cool the transmission fluid if it goes to the radiator after the tranny cooler?
Old 07-17-2012, 08:58 PM
william_04_x's Avatar
william_04_x
william_04_x is online now
The cooler in the radiator is meant to temper the fluid, and keep it within it's engineered operating temperature range. It keeps the fluid from getting too hot, or too cold.
Old 07-17-2012, 09:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,571 Likes on 1,049 Posts
That's totally wrong.
The radiator COOLER cools the ATF before it goes to the air to oil cooler, not after.
Also, the coolant is not 180°F in that side of the radiator, it's cooler than that. The radiator cools the coolant, that's why you have a radiator. The trans cooler sees coolant that has already been cooled by the radiator, so it is cooler than 180°F. After this cooler the ATF goes to the air to oil cooler to be further cooled.
This COOLER never, never warms the ATF. Never. Under no conditions. Never. Doesn't happen.
Old 07-18-2012, 06:23 AM
mrad's Avatar
mrad
mrad is offline
Mark,
Thanks for the clarification. My thought was that Ford would not design it to "heat" the fluid. I stopped at one garage yesterday to ask if he could install my 6.0 cooler. He told me that even if the bigger cooler cooled it, it would be heated when it went through the radiator.
Old 07-18-2012, 09:41 AM
az_r2d1's Avatar
az_r2d1
az_r2d1 is offline
Not even early on ? I monitor my coolant temps and the trans temp. The coolant gets up to ~ 185 pretty quickly but the trans temp takes a lot longer to warm up.
Old 07-18-2012, 12:51 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Originally Posted by az_r2d1
Not even early on ?
Nope. Never is an absolute.
Stewart
Old 07-18-2012, 04:40 PM
Mark Kovalsky
Is your trans cooler inside the engine or inside the radiator? I've only seen trans coolers in the radiator, never in the engine. Have you ever looked at the temperature in the radiator, in the tank AFTER it's been cooled? It is NOWHERE near 185°F. In cold ambients the water temperature near the trans cooler is outside temperature, plus or minus about 5 degrees. So in 0°F outside temps the cold side of the radiator will stay at about 0-5°F near the trans cooler. How well will that heat the transmission?
Never means never. It doesn't mean when it's convenient.
Old 07-18-2012, 05:54 PM
william_04_x
Another wives tale down the tubes.
Old 07-19-2012, 08:58 AM
az_r2d1's Avatar
az_r2d1
az_r2d1 is offline
wellll, you got a good point there. Didn't think of it that way. I guess it's a good indicator as to how well your Radiator is working too...
In driving in 105F weather in town (not too many stops, it's a quiet area) the trans takes a while to get up to around 170F. Coolant around 185.
Driving freeway, mostly flat , in about 105/110 weather it gets up a bit higher, 180, and the coolant temp is around 190/195
Old 08-03-2012, 10:34 PM
ironwood's Avatar
ironwood
ironwood is offline
Thanks, good info.
Ironwood
Old 08-03-2012, 11:34 PM
EXv10's Avatar
EXv10
EXv10 is offline
It's a no brainer that no part of they system is going to add heat to the trans oil when the whole objective is to keep it running cool. Things like radiator thermostats etc only bring the engine up to operating temperature a little quicker but nothing is going to add heat to anything that doesn't need more of it.
jeremywatco
07-12-2019 11:01 PM
Ron94150
10-17-2015 09:07 AM
Aaron-71
08-17-2015 02:26 PM
Dascro58
04-06-2012 09:30 PM
390unibody
09-18-2010 12:47 AM
Quick Reply: How does the through radiator transimission cooler work?
