Exhaust Manifold to Pipe Connection
Old 07-17-2012, 04:29 PM
montego69's Avatar
montego69
montego69 is offline
Hi all,
My parts guy is confused. I need some duals bent up for my 60 4X4. I've got ram's horns on the engine. Someone must make a stubby flange that bolts to the manifold and allows the rest of the exhaust to bolt up. Or is there a thick flange that welds to the down pipes?
What have you guys done?
Thanks,
Nick in WI
Old 07-20-2012, 09:05 AM
montego69's Avatar
montego69
Wow, I didn't realize it was such a hard question. Anyone with some help for me? I stopped at the local Bumper to Bumper and they also were of no help.
Old 07-20-2012, 09:50 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Donuts or flat flanges with gaskets? If they are the flat flanges, just make your own. If they are the donut type, you will need to find the collar of the proper bolt spacing, shouldn't be too hard.
It never ceases to amaze me how many "muffler" shops won't touch the manifolds. I have seen so many new complete systems and the welded onto the old rusty thin pipe to avoid doing the job right and starting from the manifold.
Old 07-20-2012, 10:59 AM
montego69's Avatar
montego69
Exhaust Shop Stop
Willowbilly3,
These have the flat surface with a gasket. I think I'm going to stop in with a manifold at the exhaust shop and see if they have any flanges available.
I might be able to make some nice, thick ones on the waterjet cutter here at work too.
Lucky for me, the guy in the shop that bends my exhaust systems is a real car guy who won't take any shortcuts.
Nick in WI
Old 07-20-2012, 05:35 PM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is offline
You are 100% right, I went to 3 different muffler shops trying to get a duel set made for my F-5. All three wanted me to bring in the flange with a piece of pipe still attatched to it. Took an old flange to a welding shop, he cut new ones out of 1/2 inch plate, then welded a short piece of pipe in, then the muffler place made the exhaust.
Old 07-21-2012, 08:51 AM
Walston's Avatar
Walston
Walston is offline
I don't have any pictures so I made a sketch. The sizes are standard, if I remember correctly the pipe is 2". Any decent exhaust shop should be able to fix you up based on this sketch.
Old 07-21-2012, 07:49 PM
spurredon's Avatar
spurredon
spurredon is offline
That looks pretty clear to me but I,,, don't bend pipes for a living either!
Old 07-22-2012, 07:43 PM
rgs4x's Avatar
rgs4x
rgs4x is offline
My muffler shop guy made my flange.
Old 07-27-2012, 11:21 AM
montego69's Avatar
montego69
Hi all,
I stopped at a couple muffler shops. Both shops have equipment that allow them to build the connection several different ways actually. the one way is to use a flat flange and weld the pipe into the ID of the flange and even telescope it a bit into the rams horn. The shop had flanges on the shelf that fit the bolt pattern. I also picked up a stamped flange that I was familiar with for later style - late 60's head pipe connections. Those later ones had the donut gasket. The pipe bender said i could use that style flange with either a single or double flat flair on the end of the pipe. The flange would be loose on the pipe like how later exhausts were built. I think both styles would work fine for what i'm doing. The shops said both styles would be easily done too.
Since the studs are typical 7/16 in size, i also got the special nuts that have a smaller wrench size - think they're 5/8" instead of maybe 11/16". The smaller diameter fits the stamped flange better.
Well, hope this helps the next guy dealing with this.
Later,
Nick in WI
mgerdau
03-29-2018 06:16 PM
blue84f250
02-06-2014 12:34 AM
hooler1
Exhaust Systems
08-10-2012 11:44 AM
zzjonze
10-09-2007 07:39 PM
Quick Reply: Exhaust Manifold to Pipe Connection
