Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 07-17-2012, 04:29 PM
montego69 montego69 is offline
Garage is empty, add now
montego69 is starting off with a positive reputation.
Exhaust Manifold to Pipe Connection
Hi all,
My parts guy is confused. I need some duals bent up for my 60 4X4. I've got ram's horns on the engine. Someone must make a stubby flange that bolts to the manifold and allows the rest of the exhaust to bolt up. Or is there a thick flange that welds to the down pipes?
What have you guys done?
Thanks,
Nick in WI
  #2 (permalink)
Old 07-20-2012, 09:05 AM
Wow, I didn't realize it was such a hard question. Anyone with some help for me? I stopped at the local Bumper to Bumper and they also were of no help.
  #3 (permalink)
Old 07-20-2012, 09:50 AM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Donuts or flat flanges with gaskets? If they are the flat flanges, just make your own. If they are the donut type, you will need to find the collar of the proper bolt spacing, shouldn't be too hard.
It never ceases to amaze me how many "muffler" shops won't touch the manifolds. I have seen so many new complete systems and the welded onto the old rusty thin pipe to avoid doing the job right and starting from the manifold.
  #4 (permalink)
Old 07-20-2012, 10:59 AM
Exhaust Shop Stop
Willowbilly3,
These have the flat surface with a gasket. I think I'm going to stop in with a manifold at the exhaust shop and see if they have any flanges available.
I might be able to make some nice, thick ones on the waterjet cutter here at work too.
Lucky for me, the guy in the shop that bends my exhaust systems is a real car guy who won't take any shortcuts.
Nick in WI
  #5 (permalink)
Old 07-20-2012, 05:35 PM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
You are 100% right, I went to 3 different muffler shops trying to get a duel set made for my F-5. All three wanted me to bring in the flange with a piece of pipe still attatched to it. Took an old flange to a welding shop, he cut new ones out of 1/2 inch plate, then welded a short piece of pipe in, then the muffler place made the exhaust.
  #6 (permalink)
Old 07-21-2012, 08:51 AM
Walston's Avatar
Walston Walston is offline
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
I don't have any pictures so I made a sketch. The sizes are standard, if I remember correctly the pipe is 2". Any decent exhaust shop should be able to fix you up based on this sketch.
__________________
Walston
http://bigjohnstractor.com/
  #7 (permalink)
Old 07-21-2012, 07:49 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
That looks pretty clear to me but I,,, don't bend pipes for a living either!
  #8 (permalink)
Old 07-22-2012, 07:43 PM
rgs4x rgs4x is offline
rgs4x is starting off with a positive reputation.
My muffler shop guy made my flange.
Click the image to open in full size.
  #9 (permalink)
Old 07-27-2012, 11:21 AM
Hi all,
I stopped at a couple muffler shops. Both shops have equipment that allow them to build the connection several different ways actually. the one way is to use a flat flange and weld the pipe into the ID of the flange and even telescope it a bit into the rams horn. The shop had flanges on the shelf that fit the bolt pattern. I also picked up a stamped flange that I was familiar with for later style - late 60's head pipe connections. Those later ones had the donut gasket. The pipe bender said i could use that style flange with either a single or double flat flair on the end of the pipe. The flange would be loose on the pipe like how later exhausts were built. I think both styles would work fine for what i'm doing. The shops said both styles would be easily done too.
Since the studs are typical 7/16 in size, i also got the special nuts that have a smaller wrench size - think they're 5/8" instead of maybe 11/16". The smaller diameter fits the stamped flange better.
Well, hope this helps the next guy dealing with this.
Later,
Nick in WI
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
