1978 Ford F250 Transmission Swap
Old 07-17-2012, 01:51 PM
Soupy1993's Avatar
Soupy1993
Soupy1993 is offline
Hello
I have a 1978 Ford F250 with a C4 Automatic Transmission and the 400 Ford. My Grandfather bought me a 4 Speed Transmission(Have no idea what kind yet) from a 1977 Ford F150 that also had the 400 Ford. I was wondering if this is going to be a direct bolt on to my truck. Or if i will need to get the crossmember from the guy we bought it from. Also, my grandfather said i may need to find a different fly wheel. I'm wondering on if this is going to be pretty simple or more complicating then we had planned. Any info would be greatly appreciated!
Thanks Guys
Old 07-17-2012, 01:57 PM
smokenchoken's Avatar
smokenchoken
smokenchoken is offline
need alot but can be worth it
there is a lot of little things you need and they add up but then again 4 speeds are great but just to name a few things you will need bellhouse, clutch fork, z bar, clutch pedal assembly for inside the cab, clutch, flywheel, pilot shaft bushing, longer drive shaft, new speedo cable if i remember right, and different cross member or just get your auto rebuilt or pick up another c6 from a 400 or 460 they both fit just my 2 cents
Old 07-17-2012, 02:10 PM
Soupy1993's Avatar
Soupy1993
Thanks for the quick reply. I'v got everything you mentioned there except for the crossmember.. so when i go to pick this transmission up i'll just have to get the crossmember from the guy. If i liked automatic trannys i'd rebuild the one i got but i was looking into getting a standard in that puppy.
Old 07-17-2012, 02:22 PM
smokenchoken
well they are a blast best of luck to your future endeavors and send some truck **** in when you get the chance
Old 07-17-2012, 03:36 PM
Soupy1993's Avatar
Soupy1993
HAHAHA! alright man will do
Old 07-18-2012, 11:37 AM
joerickson's Avatar
joerickson
joerickson is offline
I believe the crossmembers are the same, just have to slide them back on the frame. There should be holes in the frame to move it, and the holes in the crossmember should be slotted already to help out.
But then again, it cant hurt to get the extra crossmember just in case.
Old 07-19-2012, 08:46 AM
Soupy1993's Avatar
Soupy1993
Thanks again. I'll take that crossmember just to make sure. But that that makes me feel alittle better!
Old 07-19-2012, 09:45 AM
mark a.'s Avatar
mark a.
mark a. is offline
Are you working on a 2wd or 4wd ?
Old 07-19-2012, 09:54 PM
boggin79ford's Avatar
boggin79ford
boggin79ford is offline
the cross member is the same for auto or standard trans you will just have to move it up but there are holes already in the frame. you will need a longer rear drive shaft and you will have to shorten your front driveshaft. that aside from what was already mentioned. I did the swap and it was pretty simple once i had all the correct parts.
bcso290
06-05-2017 01:05 PM
kupiec20
10-21-2016 08:18 PM
Bulldog f150
29
02-07-2014 09:44 AM
tikkakoski
11-21-2010 08:46 PM
1ole4d
03-08-2002 12:34 AM
Quick Reply: 1978 Ford F250 Transmission Swap
