Floor Mount Booster/MC clearance with trans/exhaust
For those experienced with floor mount brake booster/MC setups, are there clearance issues with trans/exhaust?
I am in the process of setting an EFI 5.0L engine/trans in the frame of my 56 F100. I started centering up the engine/trans and noticed that the original looked like it was set more to the passenger side. The front suspension is stock I-beam and leafs. Got me thinking about clearance on the other side with an under cab power brake setup (Been looking at CCP unit). I looked around but didn't find this issue specifically addressed.
Can anyone tell me what I may run into?
Thanks,
John
Thanks,
John
As you realize, the drivers side is where the main problems will crop up. What transmission are you using? Floor shift or column? I have a TCI chassis, 302 engine, and AOD tranny. I'm running fox-body shorty headers, and the 87 T-bird H-pipe bolts right up. But, I'm not happy with my Flowmasters and that the tail pipe dumps the noise right in front of the axle. I have a column shift and the under cab power brakes. It all fits, but you defintiely have to be careful when selecting parts.
Thanks,
John
Thanks,
John
As you realize, the drivers side is where the main problems will crop up. What transmission are you using? Floor shift or column? I have a TCI chassis, 302 engine, and AOD tranny. I'm running fox-body shorty headers, and the mustang cross-over bolts right up. But, I'm not happy with my Flowmasters and that the tail pipe dumps the noise right in front of the axle. I have a column shift and the under cab power brakes. It all fits, but you defintiely have to be careful when selecting parts.
I am using an efi/auto tranny with floor brakes and column shift, and tubular tranny crossmember and its tight..
I don't think there is any room to get the exhaust above the tranny crossmember on the drivers side..
I currently have the temporary pipes under the crossmember on both sides.
Sam
Sam
I am using the engine and trans mission form a 98 ford explorer, I think that is a 4R70W. I plan to make it a column shift. I am planning on using the CCP booster/MC kit. Right now I am using a aftermarket trans mount and engine mount setup from f100 central. I want to center the and engine and trans as best I can, plus sit it back as far as possible too.
I have read that it is a difficult system to deal with in an EFI swap. I gotta go for a bit, but I really am interested in your progress on that.
Again, welcome to the forum! I am using the EEC IV MAF system from the '87-'93 Mustang. I have a Ford Explorer 5.0 converted the Explorer linkage to Mustang throttlebody/AOD I have some literature on it and some other stuff too.
Wow ! So you are planning to use the EEC V system. I am interested for sure!
Rellim51
18
02-26-2011 11:36 AM
hotrodbob51
01-06-2011 03:05 AM
hotrodbob51
08-18-2010 06:48 AM
Kathy1
01-20-2008 10:30 AM
Gwilkrrs
04-08-2006 12:00 AM
