2000 f150 5.4 won't start, fuel pump? - Ford Truck Enthusiasts Forums
Old 07-16-2012, 12:30 PM
gtex's Avatar
gtex gtex is offline
gtex is gaining momentum as a positive member of FTE.
2000 F150 with 5.4, struggled one time last week, but managed to start after a few tries. then yesterday it stranded me in a parking lot. sounds like it's not getting fuel. 120,000 miles. is it common for the fuel pump to give up on these trucks? I assume it's in the tank and a real bear to change. looks like the pump is pretty cheap.
G
Old 07-16-2012, 12:39 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Prove the pump is the cause before you take anything apart.
Test for fuel pressure at the fuel rail port.
It needs to be 35 to 40 psi running then hold that pressure for at least 5 min or more after shut off.
Key to run starts the fuel pump for a couple seconds then it stops.
Key on again and it should run a couple seconds again to build more pressure.
At cranking, the pump runs full time.
Good luck.
Old 07-22-2012, 05:24 PM
gtex's Avatar
pump and filter replaced. did it the hard way, like i do most things; dropped the tank. anyway, it's running smooth again :-) one less fire to put out for now. Home A/C is on the fritz and the viper won't hold a charge.
00 5.4 Starting 04mudslinger 1997 - 2003 F150 1 07-14-2014 05:10 PM
starting problems cjtim 1997 - 2003 F150 12 12-23-2011 06:24 PM
truck wont start, pulled 2 codes Ford Trucker 2008 1997 - 2003 F150 1 09-11-2009 07:15 PM
2000 F-150 Cranks but no start gbal 1997 - 2003 F150 2 07-31-2006 07:58 AM
2000 f150 codes mavman 1997 - 2003 F150 6 07-15-2002 06:55 PM
Tags
2000, 54, f150, ford, fuel, pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
