Fridge with a 460, what headers?
on
are you running the stock or aftermarket suspension?
i have a 46o witha MII suspension and use Headman headers meant for a 77-79 4x4. the only modification i had to do was bend them out a bit to clear the steering shaft and use 2 u-joints to go around the headers. the passenger side fit perfect and both sides exits above the bottom of the frame rails so the collectors are tucked up nicely and don't drag.
if i was doing it again, i would probably spring for some block hugger headers like Sanderson makes. i think they would work a lot better with less modifications required.
rgds
Mike
rgds
Mike
Amish65F100
07-11-2018 06:56 PM
william16339
12-22-2016 04:55 AM
