Broken air susp. connection by relay box under hood?
My sisters 2000 Nav. lost all the air in its suspension the other day, the bags were empty and it had no suspension in the rear end.
I was checking the fuses and relays when I found a connector right by the relay box under the hood. It's a plastic connection between two rubber hoses and the plastic split so one end falls out when it builds pressure.
Can I buy that part or can you just put a small barb to barb connector in there?
Thanks,
Joe
Thanks,
Joe
KCBS Smoker
1999 to 2016 Super Duty
25
04-14-2017 06:16 PM
