Where does this wire go?
the smog pump was froze. With a little help from a pry bar it freed up and I put the belt on. What does the pump effect
Not much, just pushes air into the cats for better reaction of whatever. But if you take the pump out, you'll need an idler in it's place or you might be able to run a shorter belt. Or just take the pump out and gut it, if you don't mind it hangin out down there.
Must add if it froze it will freeze again and will strand you w/o a water pump when it takes the belt out... address this
I am about 90%to sure the fuel pump is weak. I will know for sure tonight. Will a pump from a 95 f150 with 302 work.
love2fixit
01-07-2003 05:35 AM
