Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 07-15-2012, 09:42 PM
shanesf100's Avatar
shanesf100 shanesf100 is offline
Garage is empty, add now
shanesf100 is starting off with a positive reputation.
i1986shane
Brakes help
Im in the process of redoing my 59 f100 . I want to do a disc conversion . What parts from which vehicles would I need to convert it to disc? I know that there is conversion kits but some are quite pricy for me currently . My truck is a stock 223ci all stock suspension /spindles . I plan on a stock daily driver with good brakes .thanks for any help you can give
Click the image to open in full size.
  #2 (permalink)
Old 07-15-2012, 11:57 PM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
got a junkyard? I'd go pull a rotor from a truck with the same bolt pattern, pretty much any F-150 from mid 70s to mid 90s. Measure the spindle length, buy the rotor and bearings. Now go home and pull your drum/hub and start measuring. Inner and outer diameter for bearings and seals. Take those dimensions to any good bearing shop and they will fix you up.Depending on the spindle length, you may need a spacer made.
Remove the backing plate. At this point I usually use the cheap weld on brackets from Speedway or summit and modify them to bolt to the spindle. You will need to add some material. You can get them for the big chevy calipers or the metric ones. You'd probably want the larger. Also from Speedway you can get the hose kit. Using this method and used rotors, I have done disc brakes for way under $200. I have never bought a kit .
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
