Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Minnesota Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Minnesota Chapter Join Chapter, Leader: fordpower88
  #1 (permalink)
Old 07-15-2012, 08:39 PM
78 Custom 78 Custom is offline
Garage is empty, add now
78 Custom is starting off with a positive reputation.
Engine Perches or towers
Does anyone know where I can find a pair of Perches for a big block 460? Not sure where I can find them. Thanks
  #2 (permalink)
Old 07-16-2012, 06:21 AM
Ford79's Avatar
Ford79 Ford79 is offline
2001 Ford F-350
Ford79 is a name known to allFord79 is a name known to allFord79 is a name known to allFord79 is a name known to allFord79 is a name known to allFord79 is a name known to all
Quote:
2 wheel drive or 4x4? What year?
__________________
Mike
2001 F350 CC LB 7.3
Non OEM parts user
Roadside Help Network
  #3 (permalink)
Old 07-16-2012, 06:31 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Please, when asking questions, list all the pertinent info: Year, series, engine size, 2WD or 4WD and etc.
Your "About Me" profile says 1978 F150.
If you're looking for 460 4WD, you'll have to buy the engine mounting parts aftermarket. Ford didn't offer the 460 with 4WD or a M/T until 1983, and these parts will not work on anything prior to 1980.
1968/78 Passenger Car 460 & 1975/96 Econoline 460 engine mounting parts will not work on any year F100/350.
And, 1973/79 4WD's do not use perches, because there is no engine crossmember to bolt them to. The engine supports bolt to the inner frame rails.
1973/79 F100/350 460 2WD:
D3TZ-6028-A Right & D3TZ-6029-A Left .. Engine Supports aka perches, stands, towers.
D3TZ-6030-A Right & D3TZ-6031-A Left .. Brackets-These bolt to the block, the rubber insulators bolt to these, then to the supports.
2) D3TZ-6038-A .. Right/Left Rubber Insulators.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 07-16-2012, 03:27 PM
Devious Delight's Avatar
Devious Delight Devious Delight is offline
1977 Ford F-250
Devious Delight is gaining momentum as a positive member of FTE.Devious Delight is gaining momentum as a positive member of FTE.
I'm betting this guy can help you out...
"ALL FORD" SALVAGE YARD DOWNSIZING
__________________
Dustin
'Gert' 77 F250
  #5 (permalink)
Old 07-16-2012, 08:55 PM
1978 F 150 Custom 2wd doing a swap to a 460.Has a 300 in it now. I was told I need to get different Perches.
Thanks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
