Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 07-15-2012, 02:43 PM
bayou58 bayou58 is offline
Garage is empty, add now
bayou58 is starting off with a positive reputation.
cluster gear needed!
Ok i have a 58 ford f100 with a 3 speed manual.. it has a 223 the transmissiin reads t-85c-1 on one side the the tooth count is 16-19-26-31.. the first 2 gears have straight teeth and the rest are angled teeth.. i need the cluster gear and rear seal any help is appreciated thanks nickstickell@yahoo.com
  #2 (permalink)
Old 07-15-2012, 08:20 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Did Borg Warner make the tranny's for Chevy as well? Check this out: TRANSMISSION CLUSTER GEAR 1954 -60 CHEVY TRUCK HD | eBay
  #3 (permalink)
Old 07-15-2012, 09:19 PM
I checked it out it looks identical... just bothers me it says for gm is there anyway to make sure its the proper one
  #4 (permalink)
Old 07-16-2012, 01:13 PM
The seller said gm and ford used the same gear. I got it for $100 thanks. Guess we will see!
  #5 (permalink)
Old 07-16-2012, 01:24 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by bayou58 View Post
Ok i have a 58 ford F100 with a 3 speed manual.. it has a 223 the transmission reads t-85c-1 on one side the the tooth count is 16-19-26-31.
i need the cluster gear and rear seal.
Never believe a single word ebay sellers claim! Most have no FoMoCo literature of any kind. No parts catalogs, no shop manuals, no nothing.
The trans has been swapped, lawd only knows what it came from.
1957/60: F100 223/272/292 3 M/T without O/D & F250 223/272/292 3 M/T: C2AZ-7113-A (replaced B7C-7113-A) .. Cluster Gear: 14-17-23-27 teeth.
1957/60 F100 223/272/292 with 3 M/T O/D: B7C-7113-A .. Cluster Gear: 14-19-25-33 teeth.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #6 (permalink)
Old 07-16-2012, 01:32 PM
Ok well this gear is the proper tooth count and appearance so guess I will see if I'm lucky this time......
  #7 (permalink)
Old 07-16-2012, 01:52 PM
Ford Parts Guru
2013 Ford Escape
Better hope it's exactly the same length and has the same gear spacing, otherwise...
__________________
  #8 (permalink)
Old 07-16-2012, 02:09 PM
Yea otherwise it's an anchor.... My fingers are crossed. I actually think the seller will take returns.
  #9 (permalink)
Old 07-16-2012, 02:12 PM
I just checked. Returns accepted within 14 days of recieveing part so that works.
  #10 (permalink)
Old 07-16-2012, 05:20 PM
spurredon's Avatar
Hope it works out, you just never know!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
