ATI or RDS Auxillary Tank? - Page 3 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #31
Old 11-08-2013, 02:53 PM
Gobblin Tom Gobblin Tom is offline
Gobblin Tom is starting off with a positive reputation.
Quote:
Originally Posted by 89LX306 View Post
Tom, I actually replied in your other thread. I did have to bend the mounting tabs up at an angle. But that is all it took to get it to sit flat on the bed. I'll get the part number off my tank this weekend for you. I was planning on installing it in the new truck this weekend anyway.
Great thanks!! Maybe some pics also? I would opt for the 60 gallon if I can get it a lot cheaper.... Thought about getting that new model that covers the cap? Would be good to keep snow and stuff out of there...
  #32
Old 11-08-2013, 03:10 PM
89LX306 89LX306 is offline
89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.
Quote:
Sure thing. I'll see what I can come up with.
  #33
Old 11-08-2013, 11:30 PM
MrAgent007's Avatar
MrAgent007 MrAgent007 is offline
MrAgent007 is gaining momentum as a positive member of FTE.MrAgent007 is gaining momentum as a positive member of FTE.
Gooseneck
Will that set up work with a gooseneck? I was actually looking for a 60-80 gallon tank... That's what the company suggested I get...
Questionable on my short bed, however, I believe yes on a long bed. On my short bed, the toolbox rear edge is about 12" from where a gooseneck connection would be made.
  #34
Old 11-11-2013, 11:42 AM
Tom I posted this in the other thread as well.
I also wanted to say I had this tank in my short bed truck and I also used a SuperGlide 5th wheel hitch. Never had any problems.
Tom,
I did not install my fuel tank this weekend because this got in the way.
I did however get some pics and part numbers for you.
Here is my fuel tank part number.
Fuel pump set up.
Carter Part Number is P60504. They can be found for around $40 if you shop around.
I do not have any pics of the fuel water seperator. It is a typical filter block and fuel/water seperator filter. I'll try and get some of those this week. Hope that helps a little bit.
  #35
Old 11-13-2013, 07:29 AM
brwolfjr brwolfjr is offline
brwolfjr is starting off with a positive reputation.
I spoke with Robert from ATI yesterday, he is very knowledgable and friendly, to order a tank. A few minutes on the phoneand the order is placed for a custom tank. They are notching the tank so that it fill sit closer to the bulkhead. They are also adding an extra 2" bung on the passenger side along with a fuel gauge on the driver side. He is supposed to be emailing plans for me to sign off on later today. Did I mention that it should be in my possesion in less then 3 weeks.
  #36
Old 11-13-2013, 08:36 AM
Quote:
What is the reasoning behind everything? Did you get a tool box? How much more did it cost?
  #37
Old 11-13-2013, 08:47 AM
I am gaining almost 2 inches of bed space because of the notch out for that lip. I have a short bed with a tool box leaving me about 50 inches. Every inch counts when you are moving pallets. The up charge was 70 for custom, plus they are adding a second 2" bung in case I want to add a pump down the road.
  #38
Old 11-13-2013, 09:07 AM
How many gallon? I also have a shortbed...
  #39
Old 11-13-2013, 09:19 AM
about 47 - I am only loosing 4 gal or so
  #40
Old 11-13-2013, 04:46 PM
MrAgent007's Avatar
Glad to hear everything is working out on your tank order! ATI produces a superior product and the customer service is nothing short of first class! I am looking forward to the pictures. Don't forget to put a rubber mat below the tank!
  #41
Old 11-13-2013, 05:05 PM
i asked about a rubber mat and the response I got was only use it if I am concerned about the finish of the truck bed. I was also told to make sure the rubber goes under the mounding tabs if I use one. I am not sure if I will since I have a line x liner.
  #42
Old 11-13-2013, 05:14 PM
Mud Doc's Avatar
Mud Doc Mud Doc is offline
Mud Doc is starting off with a positive reputation.
My tank has set on a LineX liner in 2 different trucks--the area under the tank looks much better than the rest of it...it does not move around so it doesn't wear on the liner.
Joe
  #43
Old 11-13-2013, 05:47 PM
Thanks Joe
I also keep forgetting that the liner has a lifetime warrantee
  #44
Old 11-13-2013, 06:23 PM
MrAgent007's Avatar
I have a rhino liner and used a 1" rubber mat that was cut to fit the tank bottom and mounting tabs. Our tanks are made from diamond plate top and bottom and because of this, I did not want the small diamond plate edges to wear through the liner from vibrations over the years and eventually cut through the paint and into the truck bed metal. A nice quality rubber mat will prevent this from taking place. Some posts ago I had commented on where I get my rubber mats from. Their prices are reasonable and they sell top quality rubber and they custom cut the product for you. To keep the diamond plate tank bottom from wearing through your bed liner and paint, I would use a rubber mat. Just one less thing to worry about in the long run.
  #45
Old 11-14-2013, 08:46 AM
OK - I have decided a rubber mat would be a good idea. What are your thoughts on a product like a deezee bed mat? Obviously I would cut it so that it is only under the tank.
toolbox/transfer tank combo in '17 hoosierbill 2017 Super Duty 27 11-30-2016 06:17 AM
Questions about RDS auxillary tank purchase tracyclifton 6.7L Power Stroke Diesel 4 12-31-2015 11:43 AM
RDS auxiliary tank install porthole 6.7L Power Stroke Diesel 51 09-28-2015 01:57 PM
FuelBox Auxillary Fuel / Tool box combo Thomas D. 1999 to 2016 Super Duty 0 08-09-2015 12:04 PM
RDS Kit install on 2011-12 DrillbitTailor 6.7L Power Stroke Diesel 17 05-05-2012 09:32 PM
Tags
45, auxiliary, fuel, gallon, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
