You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I am purchasing a 1966 econoline supervan and would like to have some more information on it, and don't have a decoder for the VIN. I'm completely new to all of this so any help is appreciated. The VIN is E16FH749727
Hi Swampy...I as well as one other who would likely come to this forum has the books to fully decode your warranty plate.
As far as them all being built in Lorain...thats interesting as I just found a Supervan...which really shouldnt be in the yard...But if theres stuff you are needing, email me and I can go and see if it has the parts or other stuff you are seeking.
The VIN decoder on here is very hit and miss... The only totally accurate source for warranty plate decoding are the Ford Master Parts Catalog which I as well as a few others have.
- cs65
Thanks for that offer, ill definitely be sure to contact you if there is anything I can't seem to find. And there's bound to be something.
- cs65
The VIN Decoder that I posted a link for is not the one that you are referring to.
www.econolineID.com is specifically designed for 1961-1967 Econolines, and will decode only 1961-1967 Econoline data plates. It uses the Ford Truck Parts and Accessories Catalogs, Ford Econoline Shop Manuals, and other sources. All efforts have been made to correct the erroneous data found in those sources. Data and visual inspection of various Econolines have also been used to further refine the quality of the data on that website.
It won't help, as it only decodes 17 digit VIN's. No Ford truck, Econoline or Bronco prior to 1981 has a 17 digit VIN. 1948/80: 11 digit VIN / 1981 thru today: 17 digit VIN
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
Correct as always Number Dummy.
In case someone missed what I said earlier. The following VIN Decoder is specifically for 1961-1967 Econolines.
It uses the Ford Truck Parts and Accessories Catalogs, Ford Econoline Shop Manuals, and other sources. All efforts have been made to correct the erroneous data found in those sources. Visual inspection of many Econolines (i.e. crawling inside and underneath) have also been used to further refine the quality of the data on that website.
