Cam Spacer?
Old 07-14-2012, 03:36 PM
mpc07005's Avatar
mpc07005
mpc07005 is offline
Cam Spacer?
When taking apart my engine, I had about 1/4" of endplay in the cam. I'm in the process of starting reassembly, and am searching for information about the spacer Haynes mentioned. It seems to describe a spacer that goes between the thrust plate and cam (not the gear spacer). Does anyone know what this spacer looks like or the part number? There is a chance that someone has been in this engine before me and that the original spacer was lost, if it had one. Truck's in the sig, '93 5.8W or those of you on phones.
-Mike
Old 07-14-2012, 04:29 PM
mpc07005's Avatar
mpc07005
mpc07005 is offline
Popped the new cam in and still tons of endplay; less than before, but still way more than there should be, closer to ruler than dial caliper.
Old 07-15-2012, 06:26 AM
mpc07005's Avatar
mpc07005
mpc07005 is offline
Nothin? I know some of you have been in one of these before. Maybe I'll just try a new thrust plate, even though there isn't any evidence of wear at all.
-Mike
Old 07-15-2012, 06:53 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
The cam gear and thrust plate control end play.
If the gear is bolted up tight you should see about .006", indicated.
Old 07-15-2012, 09:45 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Didn't some fords come with a thin Torrington bearing between the can and the retaining plate.
Also, the core plug in the back could have been knocked out a little causing excessive movement.
Old 07-15-2012, 10:31 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The plug is just there to keep the oil inside.
Personally, if I felt there was a problem I would bolt the gear onto the cam with the plate sandwiched... outside the engine.
Easy to measure endplay that way.
Old 07-15-2012, 11:19 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Yup. Thinking it over again your right. The cam face and gear are together and plate between them. I still thought some had the thin flat bearing also though. Brain is fried from the mid 90+ temps.
Old 07-15-2012, 01:23 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Perhaps some engines do run a Torrington bearing.
I've never seen one in a stock engine.
Old 07-15-2012, 06:37 PM
mpc07005's Avatar
mpc07005
mpc07005 is offline
Popped on the Timing set and all looks well. Only half of the places I looked on line mentioned requiring the timing gear to check endplay, and Hayne's never mentioned it, only making very vague statements about a spacer that has never existed. Thanks for your help.
-Mike
Old 03-08-2020, 10:09 PM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
-Mike
There was a spacer used at one time but I think it was eliminated from service with a new design cam gear
Don't take this as gospel but I think that's what is going on.
Old 03-08-2020, 10:13 PM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
That would have been a racing type motor vehicle racing engine. You can even get roller cam bearings if you want them.
Setting of the rear cam plug is crucial in arriving at proper cam play.
Old 03-08-2020, 10:16 PM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Now how the hell did I answer a post this old? Gonna get yelled at again ...
Old 03-08-2020, 10:47 PM
sloopdog1's Avatar
sloopdog1
sloopdog1 is offline
I have learned to look at the post dates, just to prevent the same thing.
Old 03-09-2020, 05:28 AM
torq'ta 5 8's Avatar
torq'ta 5 8
torq'ta 5 8 is offline
I think you gave relevant info, that wasnt gave 8yrs ago
Old 03-09-2020, 08:13 AM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Red face
Well , what it was is this board's use of pertaining threads after the main thread. I just dropped down too far.
A third grade education does have its' limitations.
46yblock
16
02-23-2012 02:45 AM
ENCSDEI
04-29-2007 03:47 PM
Patrolman808
06-12-2006 04:20 PM
mikestrawn
04-15-2006 11:42 AM
mattri
02-22-2005 07:08 PM
Quick Reply: Cam Spacer?
