hi rpm misfire?
07-14-2012, 12:50 AM
on
hi rpm misfire?
i have a 78 f150 with a 74 351 c 2v.here recently when the rpms build it has a misfire or maybe a backfire its a deep boom boom spit type sound other than the higher rpm range it dont do it.i changed fuel filter rebuilt carb and cleaned and regapped plugs reset timing and it still does it.any ideas
07-14-2012, 12:57 AM
Look under the hood in complete darkness. Might have a wire or two jumping spark to ground.
07-14-2012, 03:36 AM
on
ill try that but would it only do it at hi rpm and not all the time
07-14-2012, 01:18 PM
Wire a porcelain resistor in a wire directly from the battery to the coil and see if it fixes it. I had the same problem on a '76 with a 390. Turned out the wire going to the coil had been stretched and wouldn't deliver the correct voltage.
07-15-2012, 01:45 AM
on
ok i might try that appreciate the help guys
bigoldtruck
11-23-2018 03:03 PM
Kennewick
13
07-27-2009 07:19 PM
78bigunns
07-25-2007 09:30 AM
8ITCOOL
05-10-2004 08:19 PM
hillbillyk
05-24-2001 10:18 PM
