Ignition Lock Cylinder
About 2 years ago I got a Ford key lock set for my truck. It included the ignition lock cylider and the door locks.
The ignition lock cylinder seems to be acting up again. It hangs up when turning the key back to remove the key.
This is the same issue I had before. The only difference is that before it was sloppy feeling too. Does anyone know why the lock cylinder is already acting up?
I'm trying to figure out how to find a matching keyed ignition lock cylinder now. I have a tag with a 7 digit code that the keys were attached to. Is this the key cut code?
I also need to know what the part number is for the correct lock cylinder. I only have the part number for the set.
My key has a letter on the shaft part next to the plastic head. Someone told me that there should be a number too, but there isn't one.
Is there any other identifying info I need to get one that matches?
I may have jumped to conclusions. It was acting almost exactly the same as it did before except for not having the sloppyness it did before.
Its been acting up for a few days. I fiddled with the steering wheel just a bit while turning the key back and forth several times. It doesn't hang up at all now and works like new again.
Do I have a problem with the steering wheel lockout? Anyone know what might be going on?
Received 3,090 Likes
on
I've seens quite a few posts over the years on here about the actuator breaking. If it breaks, can it cause the steering wheel to lock up while driving down the road?
Whats only 10 bucks, the ignition lock cylinder?
The Motorcraft ignition lock cylinder is over 60-80 dollars depending one which one you need. The BWD or Borg Warner ones are over 50 dollars.
http://www.oreillyauto.com/site/c/se...150&vi=1122286
The one I have now is a Genuine Ford replacement. I'm not sure there is anything wrong with it now.
I know I won't buy one of the cheapo ones though. I've never had all too good of luck with them.
on
I've done some more experimenting. I've tried slightly wiggling the steering wheel while turning the key, putting the steering wheel in different positions and turning the key, and trying it with the steering wheel locked and unlocked. None of these have any affect on the key hanging up. So, I'm not sure what is going on now.
Worked for me once...
Below the cylinder is a snap ring that retains it in place, flat bearing and brass gear.
The brass gear is notorious for stripping and when this occurres, you can turn the key till armageddon comes, but the plastic steering column actuator won't move.
Tritonstables
10-01-2021 11:46 AM
earlybirds
12-03-2016 10:10 PM
sambog
02-20-2005 01:44 PM
