Rear sliding window - Ford Truck Enthusiasts Forums
Rear sliding window
Old 07-13-2012, 05:50 PM
AkF250HD's Avatar
AkF250HD AkF250HD is offline
AkF250HD is starting off with a positive reputation.
Rear sliding window
My other truck has one and I like it for my dogs and for better air flow in the cab. Anyone ever put one in their truck and how much did it cost you? Can a glass specialty store like Speedyglass put one in or can use one from another truck?
Old 07-13-2012, 06:09 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
A slider from 80-97 is a direct fit. Typically they are 75-100 at a junk yard
Old 07-13-2012, 06:11 PM
AkF250HD's Avatar
Cool, i'll have to search around and see if I can find some. Does that include F150's too? Thanks.
Old 07-13-2012, 08:21 PM
garthneddy's Avatar
garthneddy garthneddy is offline
garthneddy is gaining momentum as a positive member of FTE.
I believe anything from F100s to the Fsuperdutys would have the same back glass
Old 07-13-2012, 09:13 PM
Quote:
yes f150s from 80-96
F250HD and F350 from 80-97
and F-superdutys(f450) from 88-97
Old 07-13-2012, 10:47 PM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
FYI factory solid rear window and most aftermarket sliders use the same gasket. The factory slider uses a specific gasket. So, keep that in mind. Maybe if you get a factory one, you can save the gasket and reuse it.
The CR Lawrence single pane rear sliders are pretty nice. We have had 3 different trucks with one. My friend has it too.
Old 07-13-2012, 11:57 PM
95stepside's Avatar
95stepside 95stepside is offline
95stepside has a great reputation on FTE.95stepside has a great reputation on FTE.95stepside has a great reputation on FTE.95stepside has a great reputation on FTE.95stepside has a great reputation on FTE.
i was told in the 73-79 forum that the glass is the same for them too, so 73-97. i cannot confirm this, but its probably worth looking into.
Old 07-14-2012, 08:28 AM
yes, 73-79 glass will work too, but I would try and get the newest one you can find. Slight changes over the years making them seal better
Ford flat head pros and cons Pappys53 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 04-25-2014 05:16 PM
flush rear bumper Mighty Mustang 1973 - 1979 F-100 & Larger F-Series Trucks 9 02-19-2014 10:18 PM
AC unit in a 66 B-2 1961 - 1966 F-100 & Larger F-Series Trucks 20 08-24-2011 05:54 PM
ESPAR ? goattoford 6.7L Power Stroke Diesel 4 08-12-2011 04:05 PM
Who makes a lift 4 my Truck? ShiftMX 1997 - 2003 F150 2 07-21-2005 10:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
