4.6 to 5.0 conversion?
i'm looking at a 97 f150 with a knocking 4.6 engine (definatly bottom end)
is the tranny bolt pattern the same between the 5.0 /302 and the 4.6 engine
I have a '94 f150 engine if the swap is possible or is this a can of worms? what about electronics? thanks for the help. richard
on
Not sure where the block casting number is on the MOD motors but in any event it was the early '90's CrownVic that got a 4.6 with the same trans bolt pattern as the old windsor platform, and that corresponds with the casting numbers you posted above.. F1AE = '91, F2VE = '92. That means your truck 4.6 doesn't have the same bolt pattern so the 5.0 you have ain't gonna work without also replacing the trans, wiring harness and computer.
DARISS
05-12-2003 11:12 AM
