wheel bearing
Just had this happen to mine.
The inner race is stuck to the spindle?
To pull the hub assembly, you need to make sure you have pulled in this order:
Remove tire/wheel
Remove brake caliper
Lockout cover/case
Inner snap ring (small need pliers)
Outer snap ring (pain to see, in groove on edge of hub)
Pull lockout body out
Remove spindle locknut
Remove Spindle nut washer
Remove spindle nut
After this then the hub assembly should slide right off, be sure to catch the outter bearing as it will be loose.
The race never contacts the spindle, but if it has then pictures would help greatly. You may have to turn the hub or rock it a bit to break it free if need be.
Remove tire/wheel
Lockout cover/case
Remove spindle nut
bcraig
1983 - 2012 Ranger & B-Series
10-03-2013 11:04 AM
jdubbtx
20
09-29-2007 06:04 AM
