Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-12-2012, 08:37 PM
Yardpilot Yardpilot is offline
Garage is empty, add now
Yardpilot is starting off with a positive reputation.
Early Sixties Econoline Identification
I have an Econoline that has been parked out in the weather for thirty years. I am currently digging it out of the bushes and intend to restore or fiddle with it. It is an eight door. I need some help with ID. Part of this info I have found, but I can't find any reference for the "F" transmission. The sticker on the visor says it is a four speed on the column. This vehicle was running when parked. The top is caved from heavy snow (average fifteen feet per year, and most of the roof braces are broken. Other than that, better than you would expect. For grins and giggles I hooked up a battery and sprayed some ether down the throat. Not only did she turn over, she fired briefly. I am just amazed!
Warranty Number
E14TH487486
WB 190 Color M Mod E143 Body 589 Trans F Axle 2
GVW 3600 IRS Cert. Net HP 85 RPM 3600 DSO 72
There is nothing under that IRS marking. I am having trouble getting the lines to match up in the post.
Is this a 65?
Regards,
Yardpilot
  #2 (permalink)
Old 07-15-2012, 10:14 AM
EmilBarnabas EmilBarnabas is offline
EmilBarnabas is starting off with a positive reputation.
The F transmission is indeed a four-speed Dagenham transmission.
You've got a 1964 model that was assembled in December 1963.
The combination of 170 cui engine and 4.00:1 rear axle ratio means this van was designed to haul stuff around town and not spend too much time on the highway.
You mentioned that it is an 8-door, which means that it has cargo doors on both the left and right sides. That's fairly rare in these vans.
Get the full breakdown of your dataplate info here:
www.econolineid.com
The "IRS" marking you mentioned is really "LBS," which is the total "pounds" that the van and maximum load can weigh. In your case, the van weighs about 2,600 pounds empty, so you can carry a total load of 1,000 pounds (driver, passengers, and cargo) to reach your maximum gross vehicle weight of 3,600 pounds.
  #3 (permalink)
Old 07-15-2012, 11:04 PM
Econoline Info
Thank you for the information. It is greatly appreciated. The length fits with the 90, but the tag definitely says 190. Don't quite get that. I think this will make a great cruise/parade vehicle if I can get the project off the ground. Looking good, though. Again, thanks.
Yardpilot
  #4 (permalink)
Old 07-15-2012, 11:06 PM
Thanks. Appreciate the info. The length fits the 090, but the tag definitely says 190. I don't quite get that. This should make a great cruise/parade vehicle. Again, thanks.
Yardpilot
Yup, it's that guy.
  #5 (permalink)
Old 07-15-2012, 11:22 PM
Is the WB number right up against the rivet? Many are, and most of the leading zero is behind the rivet making it look like "190" rather than "090."
Of course it's always possible that the guy punching the tags made a mistake. You know they didn't have computers back then. If they did have computers, we would have expected more mistakes.
  #6 (permalink)
Old 07-24-2012, 04:19 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Warranty Number
E14TH487486 / W.B. 090 / Color: M / Model: E143 / Body: 589 / Trans: F / Axle: 02 / GVW: 3600 / Cert. Net HP: 85 / / RPM: 3600 / DSO: 72
E14 = E100 Van.
T = 170 1V I-6.
H = Lorain OH Assembly Plant.
487486 = 1964, assembled December 1963.
90" Wheelbase.
M = Wimbledon White.
E143 = E100 Van, 3,600 lbs. GVWR
589: 5 = Red Crush Vinyl & Red Stitch Vinyl / 89 = Econoline Van.
F = Dagenham 4 Speed Manual Transmission (4 on-the-tree!).
02 = Ford WCC-C 7" Rear Axle / 4.00-1 / 2,300 lb. Rear Axle Capacity.
3,600 lbs. Gross Vehicle Weight Rating.
85 net HP @ 3,600 RPM
72: San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the Econoline from.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
