Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 07-12-2012, 07:16 PM
Knothole's Avatar
Knothole Knothole is offline
2012 Ford F-250
Knothole is starting off with a positive reputation.
Stealing my own Gas
I did not do very well with this question in the SD forum so maybe someone here that is really familiar with the 2012 gasoline line "plumbing" can point me in the right direction. I understand gas cans, so can we move beyond that. With my previous truck I could use a 3/8 length of "rubber" fuel line e/w a marine primer bulb and easily siphon gas. That is not possible with this new F250. I also know that this will make the MPG display incorrect, but that is not an issue.
I have had occasions when my chainsaw gas can has run low. I had another occasion when a kid on a 4 wheeler had run out of gas and I simply siphoned out enough for him to get home. We travel with a truck camper and Honda EU2000 generator. There is no safe place to carry a gas can, so it was a simple matter to simply siphon and fill the generator tank.
Maybe installing a "T" and shutoff valve in a convenient location. Maybe someone knows the "plumbing" well enough and can make a suggestion as to where??
__________________
<a href=http://i47.tinypic.com/rm3acn.jpg target=_blank>http://i47.tinypic.com/rm3acn.jpg</a>
2012, F250, Lariat, 6.2, FX4, 3.73
Before you Die....Take time to Live
  #2 (permalink)
Old 07-14-2012, 05:16 AM
RZAR's Avatar
RZAR RZAR is offline
2011 Ford F-350
RZAR is gaining momentum as a positive member of FTE.
Wow I am in the exact same situation as you. I carry a Lance and also have a Honda EU2000 but no space to carry extra gas for it. I thought about putting a little custom square 5 gallon metal gas tank somewhere inside the frame rails near the tank filler. Then use that extra hole next to the gas tank filler and run filler hose for the extra tank.
__________________
2011 F350 4x4 RC 6.2 4.30
  #3 (permalink)
Old 07-14-2012, 05:37 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is online now
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
How about a hitch carrier?
I suggested the same thing in knothole's other thread but never saw a response...
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #4 (permalink)
Old 07-14-2012, 12:48 PM
Knothole's Avatar
2012 Ford F-250
I have a hitch carrier. It would interfere with the steps, and would have to be unloaded and removed before you could access the camper. Sure it would work, but life would be simpler just pumping/siphoning from the truck's fuel tank.
__________________
  #5 (permalink)
Old 07-17-2012, 09:32 AM
Mello Mike's Avatar
Mello Mike Mello Mike is offline
2011 Ford F-250
Mello Mike is starting off with a positive reputation.
I, too, have a truck camper. Have you considered installing a front hitch and buying a hitch hauler carrier? Lots of truck camper owners do this.
  #6 (permalink)
Old 07-17-2012, 08:00 PM
Knothole's Avatar
2012 Ford F-250
I have a grill guard/winch, so that option is probably out also. I have not given up, I just have not had time to do some crawling around. I figured a Ford tech. would have the quick answer.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
